Forum Topic - i.MX51 graphics issue:
I like to show somthing on the display connected with i.MX51 board through DVI.
I downloaded BSP from Foundry27.
I tried to use egl-gears-lite which was ARMLE version in IDE.
But I got this error.
# egl-gears-lite
Couldn't find a compatible frame buffer configuration on layer 0
Could you please let me know how to make it work ?
Or the easiest way to show some graphics on the screen.
Best Regards,
                           - Inami
RE: i.MX51 graphics issue
Are you able to run any 2D applications such as vsync?
Do you have the software 3D library on your target?
(devg-soft3d-fixed.so)
If you try the following it will tell you if you're missing a library:
DL_DEBUG=1 egl-gears-lite
Mike
From: Kazunori Inami [mailto:community-noreply@qnx.com]
Sent: April 6, 2010 4:03 AM
To: advanced-graphics
Subject: i.MX51 graphics issue
through DVI.
# egl-gears-lite
Best Regards,
                           - Inami
Advanced Graphics
http://community.qnx.com/sf/go/post51187
Re: RE: i.MX51 graphics issue
Hello Mike,
Thank you for you advice.
I had installed only devg-soft3d.so.
And I added devg-soft3d-fixed.so.
It start running now.
Also vsync is running.
Thank you for your help.
Best Regards,
                         - Inami
> Thanks
> Mike
> Hello,
> through DVI.
> # egl-gears-lite
> Best Regards,
>                            - Inami
> Advanced Graphics
