Re: interrupt entry point
06/17/2009 8:53 AM
post31953
Interrupts first transfer to the intr_entry_start code sequence in
kernel.S, but that code is not used in place so placing a probe at that
address will not show anything. Instead, the instructions at intr_entry_start
through intr_entry_end labels are copied to dynamically allocated memory and
intermixed with the interrupt_id and eoi callouts from the startup code.
See the cpu_interrupt_init() function in ker/x86/init_cpu.c for where
that happens.
On Tue, Jun 16, 2009 at 12:26:30PM -0400, Pietro Descombes wrote:
> Hi everyone,
> I'm trying to find the interrupt entry point. On X68, does the CPU
> directly jump to the handler pointed to by the 'interrupt_vector[]' or
> is there a function equivalent to linux 'do_IRQ()' ?
> My goal is to monitor interrupts on my own tracer but I can't find where
> to put my probes.
> (( 'nano_interrupt.c', 'ker_interrupt.c' even 'x86/kernel.S' didn't help
> me much. The 'level' and 'itp->id' parameters of interrupt_mask
> (nano_interrupt.c) are often 1 and 5 respectively, while I expect to
> receive at least the timer IRQ frequently which should be interrupt '0'
> on x86. ))
> Cheers,
> Pietro
> Using Momentics 6.4.0, instrumented kernel.
> http://community.qnx.com/sf/go/post31895
