Forum Topic - interrupt entry point:
Hi everyone,
I'm trying to find the interrupt entry point. On X68, does the CPU
directly jump to the handler pointed to by the 'interrupt_vector[]' or
is there a function equivalent to linux 'do_IRQ()' ?
My goal is to monitor interrupts on my own tracer but I can't find where
to put my probes.
(( 'nano_interrupt.c', 'ker_interrupt.c' even 'x86/kernel.S' didn't help
me much. The 'level' and 'itp->id' parameters of interrupt_mask
(nano_interrupt.c) are often 1 and 5 respectively, while I expect to
receive at least the timer IRQ frequently which should be interrupt '0'
on x86. ))
Cheers,
Pietro
Using Momentics 6.4.0, instrumented kernel.
Re: interrupt entry point
Interrupts first transfer to the intr_entry_start code sequence in
kernel.S, but that code is not used in place so placing a probe at that
address will not show anything. Instead, the instructions at intr_entry_start
through intr_entry_end labels are copied to dynamically allocated memory and
intermixed with the interrupt_id and eoi callouts from the startup code.
See the cpu_interrupt_init() function in ker/x86/init_cpu.c for where
that happens.
On Tue, Jun 16, 2009 at 12:26:30PM -0400, Pietro Descombes wrote:
> Hi everyone,
> to put my probes.
> on x86. ))
> Cheers,
> Pietro
> http://community.qnx.com/sf/go/post31895
Hi Brian,
thanks for your help, it did help me! It wasn't easy, but I managed to get things to work.
cheers!
Pietro
