Re: Commit #209305 to libc
03/05/2009 4:58 PM
post23722
There's been a lot of discussion of this general issue as part of PR#
65776 (although I don't recall if anyone brought up re-ordering).
http://community.qnx.com/sf/discussion/do/listPosts/projects.core_os/discussion.osrev.topc6394
My opinion is that _Mtxinit() should include a barrier if any is
required.
On Thu, 2009-03-05 at 15:39 -0500, Oleh Derevenko wrote:
> I was just reviewing commit log for libc for fun and noticed the following thing.
> - _Mtxinit(&str->_Flock);
> + _Mtxinit(&_Mtx);
> + str->_Flock = _Mtx;
> The comment says:
> PR:63915
> CI:cburgess
> CI:dbailey
> CI:bstecher
> CI:acripps
> For statically allocated streams (stdio, stderr, stdout etc), multiple
> threads are trying to call fprintf at the same time, and one thread is
> attempting to initialise the stream mutex (in InitLocks, there is a
> potential window for a race condition, where a second thread may
> perform the test for the existence of
> the lock, and go on to use it before the first thread has
> initialised the mutex completely. This could leave the mutex in an
> inconsitent state and even locked
> by an owner well after the thread has completed the fprintf operation.
> This solution is to ensure that the the stream lock is assigned to the
> stream only after initialisation of the mutex has completed.
> So my question is: for multiprocessor system where writes can be re-ordered, is not initialization of mutex into a
local varaible and its assignment to a shared variable potentially as dangerous as initialization in place? What if
writes will be reordered and for some other thread value in shared varaible still appears before mutex is completely
initialized? Should not memory barrier be used here to separate these two operations?
> http://community.qnx.com/sf/go/post23707
03/06/2009 9:42 AM
post23767
No, it doesn't need a barrier instruction. The mutex isn't in the _Mtx
variable, it's in the memory pointed to by the variable.
> + _Mtxinit(&_Mtx);
> The comment says:
> PR:63915
> CI:cburgess
> CI:dbailey
> CI:bstecher
> CI:acripps
