Forum Topic - Commit #209305 to libc:
I was just reviewing commit log for libc for fun and noticed the following thing.
-			_Mtxinit(&str->_Flock);
+			_Mtxinit(&_Mtx);
+			str->_Flock = _Mtx;
The comment says:
PR:63915
CI:cburgess
CI:dbailey
CI:bstecher
CI:acripps
For statically allocated streams (stdio, stderr, stdout etc), multiple
threads are  trying to call fprintf at the same time, and one thread is
attempting to initialise the stream mutex (in InitLocks, there is a
potential window for a race condition, where a second thread may
perform the test for the existence of
the lock, and go on to use it before the first thread has
initialised the mutex completely. This could leave the mutex in an
inconsitent state and even locked
by an owner well after the thread has completed the fprintf operation.
This solution is to ensure that the the stream lock is assigned to the
stream only after initialisation of the mutex has completed.
So my question is: for multiprocessor system where writes can be re-ordered, is not initialization of mutex into a local
 varaible and its assignment to a shared variable potentially as dangerous as initialization in place? What if writes
will be reordered and for some other thread value in shared varaible still appears before mutex is completely
initialized? Should not memory barrier be used here to separate these two operations?
Re: Commit #209305 to libc
There's been a lot of discussion of this general issue as part of PR#
65776 (although I don't recall if anyone brought up re-ordering).
http://community.qnx.com/sf/discussion/do/listPosts/projects.core_os/discussion.osrev.topc6394
My opinion is that _Mtxinit() should include a barrier if any is
required.
> +			_Mtxinit(&_Mtx);
> The comment says:
> PR:63915
> CI:cburgess
> CI:dbailey
> CI:bstecher
> CI:acripps
local varaible and its assignment to a shared variable potentially as dangerous as initialization in place? What if
writes will be reordered and for some other thread value in shared varaible still appears before mutex is completely
> http://community.qnx.com/sf/go/post23707
Well, it may include, but just as well it may not. It's not evident from function name and from abstract programming
logic you can't assume anything about implementation of function that is not even a part of current program unit.
Actually I was suggesting that it should be made so if that isn't
currently the case.  It is good software engineering practice to
encapsulate correctness guarantees.
> http://community.qnx.com/sf/go/post23727
No, it doesn't need a barrier instruction. The mutex isn't in the _Mtx
variable, it's in the memory pointed to by the variable.
> +			_Mtxinit(&_Mtx);
> The comment says:
> PR:63915
> CI:cburgess
> CI:dbailey
> CI:bstecher
> CI:acripps
Right, but you need to make sure, the memory of mutex is written before the memory of pointer. How can you be sure
without a barrier?
without a barrier?
Because we go into the kernel to initialize the mutex and kernel calls
all have (implicit) memory barriers before they come back to user code.
Well, that is a solid argument. :-) I just wanted to make sure you do not initialize mutex in user mode with something
like PTHRED_MUTEX_INITIALIZER.
