03/02/2009 10:19 AM
post23201
Dear QNX community,
We have developed a realtime QNX application that uses a FPGA PCI device to perform some time-critical tasks. The device
raises an interrupt on line 0x9 every 10 usec (100KHz), and the application has to respond inside this period.
This works, most of the time. However, once every minute or so, we miss *exactly* 270 usec worth of interrupts. Kernel
tracing says nothing happens in this period: The interrupt handler is entered exactly on time, and finishes 270 usec
later instead of the usual <1 usec. During this period nothing seems to happen, no interrupts, no process running.
Afterwards, normal service resumes.
I can send the .kev file if needed, but it is rather large.
We have disabled almost every hardware device (except for the network card and serial ports which we require), and every
timing- or interrupt-related BIOS option, and are running out of ideas.
Any hint, or ideas where to look next, would be greatly appreciated!
Kind regards,
- Theo van Klaveren
03/02/2009 10:22 AM
post23203
> From: Theo van Klaveren [mailto:community-noreply@qnx.com]
> Sent: March-02-09 10:20 AM
> To: ostech-core_os
> Subject: Interrupt latency
> Dear QNX community,
> device to perform some time-critical tasks. The device raises an
> *exactly* 270 usec worth of interrupts. Kernel tracing says nothing
> time, and finishes 270 usec later instead of the usual <1 usec. During
If this is x86, it well could be the infamous SMI.
http://en.wikipedia.org/wiki/System_Management_Mode
> card and serial ports which we require), and every timing- or
> Kind regards,
> - Theo van Klaveren
> http://community.qnx.com/sf/go/post23201
Re: RE: Interrupt latency
03/02/2009 10:53 AM
post23210
> > To: ostech-core_os
> > Dear QNX community,
> > this period nothing
Yes, this is x86, and yes, this could very well be it! Any ideas on how to work around?
I forgot to mention in the original post, this behaviour stops after a certain period of time.
- Theo
RE: RE: Interrupt latency
03/02/2009 10:58 AM
post23213
> to work around?
Only work around is to contact the maker and ask if the motherboard/bios supports disabling SMI. Sometimes disabling
certain feature like USB emulation, will help reduce the duration or number of invocation of the SMI.
> - Theo
> http://community.qnx.com/sf/go/post23210
Re: RE: RE: Interrupt latency
03/03/2009 9:03 AM
post23306
> > to work around?
> supports disabling SMI. Sometimes disabling certain feature like USB
Mario,
Thanks very, very much for your help. The problem is solved. I disabled SMI using a modified version of code posted on
the Foundry27 forum, here:
http://community.qnx.com/sf/discussion/do/listPosts/projects.bsp/discussion.bsp.topc5720
The (modified) code works on Intel ICH4, and I'll post it here for posterity:
#include <stdlib.h>
#include <stdio.h>
#include <hw/pci.h>
#define BIT(n) (1 << (n))
// REGISTER LOCATIONS
#define SMI_LOCK BIT(4)
#define SMI_EN BIT(3)
int
main(int argc, char *argv[])
int pci;
int rv;
int bus;
int func;
unsigned reg;
unsigned readback;
// Attach pci device
pci = pci_attach(0);
if (pci < 0) {
perror("pci_attach");
return -1;
rv = pci_find_device(0x3580, 0x8086, 0, &bus, &func);
if (rv == PCI_DEVICE_NOT_FOUND || rv < 0) {
printf("device not found\n");
return -1;
//_smi_device = p.GetDeviceObject(0x8086 , 0x2918);
// vid=0x8086 , did=0x2918
pci_read_config32(bus, func, 0x60, 1, ®);
printf("%8X\n", reg);
if (reg & SMI_LOCK)
printf("SMI LOCK is set! Nothing we can do here :-(\n");
return -1;
printf("SMI_LOCK not set.\n");
if (!(reg & SMI_EN)) {
printf("SMI_EN already unset!\n");
return 0;
reg &= ~(SMI_EN);
pci_write_config32(bus, func, 0x60, 1, ®);
pci_read_config32(bus, func, 0x60, 1, &readback);
if (!(readback & SMI_EN)) {
printf("Success!\n");
return 0;
} else {
printf("Fail!\n");
return 0;
return 0;
Thanks again,
- Theo
RE: RE: RE: Interrupt latency
03/03/2009 9:06 AM
post23307
> Sent: March-03-09 9:03 AM
> To: ostech-core_os
> Subject: Re: RE: RE: Interrupt latency
> how
> > > to work around?
> motherboard/bios
> the SMI.
> Mario,
Glad I could help.
> I disabled SMI using a modified version of code posted on the Foundry27 forum,
> here:
You have to be careful when disabling this feature. I've seen BIOSes proving watchdog feature, which can't work (endless
reboot) with SMI disable. Same thing for USB keyboard emulation.
> sion.bsp.topc5720
> posterity:
> #include <stdlib.h>
> #include <stdio.h>
> #include <hw/pci.h>
> int
> int pci;
> int rv;
> int bus;
> int func;
> unsigned reg;
> unsigned readback;
> if (pci < 0) {
> return -1;
> return -1;
> if (reg & SMI_LOCK)
> return -1;
> return 0;
> reg &= ~(SMI_EN);
> return 0;
> } else {
> printf("Fail!\n");
> return 0;
> return 0;
> Thanks again,
> - Theo
> http://community.qnx.com/sf/go/post23306
Re: RE: RE: RE: Interrupt latency
03/03/2009 10:59 AM
post23358
> > To: ostech-core_os
> > how
> > > > to work around?
> > motherboard/bios
> > the SMI.
> > Mario,
> Glad I could help.
> forum,
> > here:
> watchdog feature, which can't work (endless reboot) with SMI disable. Same
Right. It works on the (older) testing board I have here; in the actual machines (slightly newer boards) this causes a
hard crash when the interrupts start coming.
Any ideas on how to circumvent? There seem to be no BIOS options for watchdogs or keyboard emulation.
03/04/2009 8:39 AM
post23453
> > > To: ostech-core_os
> > > how
> > > > > to work around?
> > > motherboard/bios
> > > the SMI.
> > > Mario,
> > Glad I could help.
> > forum,
> > > here:
> machines (slightly newer boards) this causes a hard crash when the interrupts
> start coming.
It turns out, the code was wrong. Here is the correct source, as now in use, which actually works on both platforms:
#include <stdlib.h>
#include <stdio.h>
#include <hw/inout.h>
#include <hw/pci.h>
#include <sys/mman.h>
#include <sys/neutrino.h>
/* PCI device information */
#define PLATFORM "Intel ICH4"
#define PCI_VENDOR 0x8086 /* Vendor: Intel Corporation */
//#define PCI_DEVICE 0x3580 /* Device: Intel 825GM Host/PCI bridge */
#define PCI_DEVICE 0x24C0 /* Device: Intel 82801DB/DBL (ICH4/ICH4-L) LPC Interface Bridge */
/* Register locations */
#define PM_BASE 0x40
#define GEN_PMCON_1 0xA0
#define SMI_LOCK (1<<4)
#define ACPI_SMI_CNTL 0x30
#define GBL_SMI_EN (1<<0)
int
int pci;
int rv;
int bus;
int func;
unsigned int reg;
unsigned int pmbase_addr;
uintptr_t pmbase;
printf("SMI disable hack for " PLATFORM "\n");
/* Attach pci. */
if (pci < 0) {
return -1;
/* Find the PCI host bridge device. */
rv = pci_find_device(PCI_DEVICE, PCI_VENDOR, 0, &bus, &func);
printf("Device not found.\n");
return -1;
pci_read_config32(bus, func, PM_BASE, 1, ®);
printf("PMBASE: %08X\n", reg);
pmbase_addr = reg & 0xFF80;
pci_read_config32(bus, func, GEN_PMCON_1, 1, ®);
printf("GEN_PMCON_1: %08X\n", reg);
if (reg & SMI_LOCK) {
printf("SMI_LOCK is set, nothing we can do!\n");
return -1;
if (ThreadCtl(_NTO_TCTL_IO, 0)) {
perror("_NTO_TCTL_IO");
return -1;
pmbase = mmap_device_io(128, (uint64_t)pmbase_addr);
if (pmbase == MAP_DEVICE_FAILED) {
printf("Failed to map I/O space.\n");
return -1;
reg = in32(pmbase + ACPI_SMI_CNTL);
printf("ACPI_SMI_CNTL before: %08X\n", reg);
if (!(reg & GBL_SMI_EN)) {
printf("GBL_SMI_EN already cleared, success.\n");
return 0;
reg &= ~(GBL_SMI_EN);
out32(pmbase + ACPI_SMI_CNTL, reg);
printf("ACPI_SMI_CNTL after: %08X\n", reg);
if (reg & GBL_SMI_EN) {
printf("GBL_SMI_EN not cleared, failed!\n");
return...
03/02/2009 11:29 AM
post23218
> to work around?
You can probably access the SMI pin on the CPU and check if it's activated.
> - Theo
