09/05/2008 2:23 PM
post12964
On Thu, Sep 04, 2008 at 03:35:30PM -0400, Mario Charest wrote:
> > On Thu, Sep 04, 2008 at 02:27:33PM -0400, Mario Charest wrote:
> > > There seems to be two shutdown functions. One in sys/socket.h and one in
> > sys/shutdown.h. They both take the same kind of argument. Are they the same?
> > > Can a program linked with the socket library call the shutdown function that
> > can reboot the machine or will endup trying to shutdown a socket ;-)
> > They're different. The imposter's in libshutdown.a and doesn't
> > appear to be docked AFAICT. You should get a conflict at link
> > time if you're trying to bring them both in.
> > -seanb
> Haven't check on 6.4 but in 6.3.2 sys/shutdown.h will give a compiler error unless stdint.h is included prior to
including sys/shutdown.h.
> I guess that's too lake to change the function name in libshutdown, the damage is done?
It's probably possible to change it since it's only in a
static library. It would mean updating everything that
calls it and a release note. I'll make a PR.
