QNX 7.1 Neutrino screen output RGB value range is limited to [0x10~0xEB]
08/11/2022 4:00 AM
post121892
I connected QNX 7.1 HDMI output to an Xilinx video capture device and found that the pixel RGB value range is limited to
[0x10~0xEB] but not [0x00~0xFF]. For example, when I display red (0xFF0000) color on QNX, we got color (0xEB1010) on
video capture device, and when we display black (0x000000) color, we got color (0x101010).
Some pixels value mapping
Pixel on QNX Pixel on video capture
00 10
01 10
02 11
03 12
04 13
05 14
06 15
07 16
08 16
09 17
0A 18
0B 19
0C 1A
0D 1B
0E 1C
FD E9
FE EA
FF EB
However, when we connected ubuntu/Window10 HDMI output to the same video capture device, everything works fine.
When I used screenshot utility to capture the display on QNX 7.1, we got the correct color(the RGB range is [0x00~0xFF])
The graphics.conf is:
begin khronos
begin egl display 1
egl-dlls = libglapi-mesa.so libEGL-mesa.so
glesv1-dlls = libglapi-mesa.so libGLESv1_CM-mesa.so
glesv2-dlls = libglapi-mesa.so libGLESv2-mesa.so
gpu-dlls = gpu_drm.so
end egl display
begin wfd device 1
wfd-dlls = libwfdcfg-intel-generic.so libWFDintel-drm.so
# Run "drm-probe-displays" to list the available displays and pipelines,
# and "use $GRAPHICS_ROOT/libWFDintel-drm.so" for more information on
# these driver-specific settings.
# Here is displays map for DH370:
# display 1: DisplayPort (DP-1)
# display 2: DisplayPort (DP-2)
# display 3: HDMI-A (HDMI-A-1)
# display 4: DisplayPort (DP-3), default
# display 5: HDMI-A (HDMI-A-2)
# display 6: DisplayPort (DP-4)
# display 7: HDMI-A (HDMI-A-3)
# Pipeline IDs 1 to 9 are used for DRM CRTCs. One should be assigned
# to each display that will be used.
pipeline1-display = 1
pipeline2-display = 2
pipeline3-display = 4 # this is the display id which identified by drm-probe-display, the only hdmi output on DH370
end wfd device
end khronos
begin winmgr
begin globals
default-display = 4 # the default display id, 4 is the only one hdmi output on DH370
# Adjust the stack size of Screen's resmgr threads. The default size
# is insufficient for blitters/compositors using Mesa (e.g., gles2blt).
stack-size = 65536 # in units of bytes
blit-config = inteldrm
alloc-config = inteldrm
requests-logsize = 65536
blits-logsize = 4096
end globals
begin display 1
video-mode = 1920 x 1080 @ 60
# Adjust the stack size of Screen's composition thread; required when the
# display's framebuffer uses Mesa (e.g., "usage = gles2"), as noted above.
end display
begin display 2
end display
begin display 4
end display
begin class framebuffer-1
display = 1
pipeline = 1
format = rgba8888
usage = inteldrm
end class
begin class framebuffer-2
display = 2
pipeline = 2
format = rgba8888
usage = inteldrm
end class
begin class framebuffer-3
display = 4
pipeline = 3
format = rgba8888
usage = inteldrm
end class
end winmgr
/root# cat...
