Forum Topic - possible performance lag with core affinities using _devctl(): (2 Items)
We explicitly sets the CPU affinity on every thread switch, usually it narrows it down to the CPU the thread is running
on when a thread became RUNNING and it widens it to all CPUs before the thread becomes READY or BLOCKED.  We see that
thread switch overhead on QNX is significantly higher than on Linux, one benchmarks runs 4x slower. We suspect that the
relatively complex affinity setting code might be the culprit, in particular the case in which  _devctl() is used.
Is there any knowledge about known performance bottlenecks regarding this?
I have attached a segment of our glue layer sources that use this call.
The function showing the _devctl() usage is:
"JAMAICA_LOCAL int jamaicaNativeQNXThread_runmask_get_and_set"
David Beberman
aicas
Attachment: Text jamaica_native_thread.c 10.73 KB
Re: possible performance lag with core affinities using _devctl()
Yes, open/_devctl/close is much more expensive than ThreadCtl
You're trying to prevent migrations?
running on when a thread became RUNNING and it widens it to all CPUs before the thread becomes READY or BLOCKED.  We see
 that thread switch overhead on QNX is significantly higher than on Linux, one benchmarks runs 4x slower. We suspect
that the relatively complex affinity setting code might be the culprit, in particular the case in which  _devctl() is
used.
> Thanks,
> David Beberman
> aicas
> http://community.qnx.com/sf/go/post111862
