Forum Topic - devb-eide core dump: (6 Items)
devb-eide core dump
I have attached a core dump of devb-eide.
This started to happened after I updated my runtime image to 6.3.2.  I doubled checked and I am confident I didn't miss
a file during the process.
I can get it to crash consistenly, just have to copy a directory with lots (100) of files/directory in it.  The files
are copied over the network, but I get the feeling that's not related.
Attachment: Text devb-eide.core.7z 2.16 MB
Re: devb-eide core dump
>  checked and I am confident I didn't miss a file during the process.
> 100) of files/directory in it.  The files are copied over the network, but I
Somebody else is having the exact same problem.  It crashes at the same address.
http://www.openqnx.com/index.php?name=PNphpBB2&file=viewtopic&p=41381#41381
Is this the right place to post for this?
Any holiday I wasn't aware of?
> doubled
> address.
Hello Mario,
IMHO, BSP and Drivers would have been better.
No.
> > doubled
Waht was Your  exact update procedure ?
As a starting point I would suggest that You issue a
pidin -pdevb-eide mem
and post all cksums of the involved libs/*.so's  and tell the place where they are accessed from.
Just want to exclude a stupid library version missmatch.
>  I
> > address.
Jeevan
We believe that we have located the problem.  It appears to lie within the io-blk.so code.
When the blk ramdisk=xxx option is used, a path has been found where a ramdisk's buffer can be cleaned when invalidated.
  When using the ramdisk (not to be confused with devb-ram), the buffers should not be cleaned when invalidated.  In the
 case of this forum's thread, this eventually leads to crashing the devb-eide driver.
Until fixed, the suggested workaround is to use devb-ram instead of using the blk ramdisk=xxx option with devb-eide or
the other devb-xxx drivers.
Peter Mitsis
> blk.so code.
> ramdisk's buffer can be cleaned when invalidated.  When using the ramdisk (not
> invalidated.  In the case of this forum's thread, this eventually leads to
> blk ramdisk=xxx option with devb-eide or the other devb-xxx drivers.
> Peter Mitsis
Just want to confirm that not using the ramdisk (devb-eide) solved the crashing problem for us.
Thanks.
