Forum Topic - Unable to download source code: (5 Items)
I have a vald login and I am trying to download code for some utilities but  I keep getting permission denied errors.
Can someone please help.
Re: Unable to download source code
Following is the error I get
Warning: array_key_exists(): The first argument should be either a string or an integer in /www/web_app/htdocs/monitor/
ping.php on line 134
Hello Sabtain:
We have updated our source code access policies please see the changes
at the link below:
http://community.qnx.com/sf/wiki/do/viewPage/projects.community/wiki/UpdatedQNXSourceAccessPolicyFAQ
Additionally it also links to a form required to download Restricted
source code.
Gervais
> http://community.qnx.com/sf/go/post56297
Gervais,
             I work for AECL and I have worked with you before if you remember. I was able to get code from OS project
before. Do I need to fill that form as well? I should have access as well
Hello Sabtain:
I do remember you this is why I jumped at the chance to give you a hand.
Which URL are you using so I can investigate.
Gervais
On 06/08/10 11:36, sabtain khan wrote:
> Gervais,
project before. Do I need to fill that form as well? I should have access as well
> http://community.qnx.com/sf/go/post56305
