__cpu_membarrier implementation
02/04/2010 8:10 AM
post46522
In trunk/lib/c/public/x86/cpuinline.h __cpu_membarrier defined as
# define __cpu_membarrier() \
/* check for X86_CPU_SSE2 */ \
if (__cpu_flags & (1 << 15)) { \
__asm__ __volatile__ ("mfence"); \
} else { \
__asm__ __volatile__ ("lock; orb $0,0(%esp)"); \
In trunk/lib/c/public/x86/smpxchg.h _smp_xchg defined as
static __inline int __attribute__((__unused__)) _smp_xchg(volatile unsigned *__dst, unsigned __src) {
__asm__ __volatile__(
"xchgl %0,%1"
:"=r" (__src)
:"m" (__atomic_fool_gcc(__dst)), "0" (__src)
:"memory");
return __src;
A question is: is not "memory" required in clobber list for __cpu_membarrier? As far as I understand that makes sure
compiler does not reuse values evaluated from memory across the assembler block.
