We need implement a database system in QNX6.4, but we don't sure about what engine to use. Someone have an idea to wich database to use, such as sybase, MySql..etc
The databases which work in 6.2 or 6.3 should work in 6.4. The choice of the base depends first of all on what you needs. Large or the small base. Given on the disc or in the RAM memory. Look: Raima Database Manager (RDM) Embedded => http://www.raima.com/products/rdm-embedded/specification/ McObject’s embedded database - eXtremeDB => http://www.mcobject.com/embedded_database_products MySQL 5.0 - http://dev.mysql.com/get/Downloads/MySQL-5.0/mysql-5.0.67-nto-qnx6.2.1-i386.tar.gz - I try it in 6.4 work very well. Empress RDBMS => http://www2.empress.com/qnx/empqnx.html Oracle Berkeley DB => http://www.oracle.com/technology/products/berkeley-db/db/index.html very good work on 6.4 DB2® Everyplace® Enterprise Edition => http://publib.boulder.ibm.com/infocenter/db2e/v9r1/index.jsp?topic=/com.ibm. db2e.doc/dbeint0316.html SQLite => http://www.sqlite.org/ work on QNX 6.3/6.4
Thanks For your answer, we are using MySQL in all of our applications and we are very happy with it. Do you know if MySQL is making the binaries for the QNX newer versions? Thanks
On Fri, Sep 11, 2009 at 01:50:23PM -0400, mariana viale wrote: > Thanks > > For your answer, we are using MySQL in all of our applications and we are very happy with it. > Do you know if MySQL is making the binaries for the QNX newer versions? You can get it here: ftp://ftp.netbsd.org/pub/pkgsrc/packages/QNX/i386/6.4.1_head_20090724/All Check out the pkgsrc project: http://community.qnx.com/sf/projects/pkgsrc -seanb
