Re: QNX neutrino installation
08/01/2008 9:15 AM
post11322
You indicated that it takes around 10 minutes to build. Could you please explain what are you building?
Please type
qconfig
and post the output.
Yuriu
08/01/2008 9:26 AM
post11324
Neutrino version of IDE is generally very slow because of problem with
underlining java implementation.
While we working on it, is recommended to use IDE on windows or linux
host and do cross platform compilation and remote debugging.
murugadoss v wrote:
> I have installed the Qnx neutrino in my system. when i open IDE and
> work, the system is very slow, it takes around 10min to build. What may
> be the issue. My system configuration,
> ram - 512Mb
> harddisk - 40Gb
> processor - AMD processor
> Note: i am using windows in same system by partitioning
> can u say what may be issue?? what would be better solution for it??
> Thanks
