Re: Getting momentics on neutrino 6.4.1 sdp
05/21/2010 8:22 AM
post55355
Hey guys, thanks heaps for the help!
Figured out how to make neutrino compile and build .c files!
Now need to figure out how to make the build file i made actually run a c program i made
i created a executable by doing
'qcc -Vgcc_ntox86 -o myfile myfile.c'
just trying to figure out how to make the boot image run the 'myfile' application i looked up in the 'building embedded
systems' document it said the following:
"There’s nothing special required to run your applications. Generally, they’ll be placed
in the script file after all the other drivers have started. If you require a particular
driver to be present and “ready,” you would typically use the waitfor command in
the script.
Here’s an example. An application called peelmaster needs to wait for a driver (let’s
call it driver-spud) to be ready before it should start. The following sequence is
typical:
driver-spud &
waitfor /dev/spud
peelmaster
the file im trying to run outputs to console and i have the console running i can open the file manually after boot up
but want it to open automatically tried to do
wait for/dev/con
myfile
and it doesnt open the file any ideas?
Thanks heaps again
this is the build file.
Thanks so much again im going crazy :(
[virtual=x86,bios +compress] boot = {
startup-bios -s64k
PATH=/proc/boot procnto
[+script] startup-script = {
# To save memory, make everyone use the libc in the boot
# image! For speed (fewer symbolic lookups), we point to
# libc.so.3 instead of libc.so.
procmgr_symlink ../../proc/boot/libc.so.3 /usr/lib/ldqnx.so.2
display_msg Welcome to QNX NeutriNo
ooooooooooooo
devc-con &
reopen dev/con1
# Start the PCI server
seedres
pci-bios &
waitfor /dev/pci
# Start IDE and mount the flash disk in /usr/hdd
devb-eide blk automount=hd0t77:/usr/hdd &
# Some common servers
pipe &
mqueue &
devc-ser8250 &
devc-pty &
# Start a debug server for debugging programs
waitfor /dev/ser1
[+session] pdebug /dev/ser1 &
# These env variables inherited by all the programs which follow
SYSNAME=nto
TERM=qansi
# Start the main shell
reopen /dev/con1
[+session] sh
# Make the /temp point to the shared memory area
[type=link] /tmp=/dev/shmem
# Programs require the runtime linker (ldqnx.so) to be at a fixed location
[type=link] /usr/lib/ldqnx.so.2=/proc/boot/libc.so
libc.so.2
libc.so
libhiddi.so
libusbdi.so
#devn-smc9118.so
devnp-shim.so
libsocket.so
[type=link] /lib/stdc++.so.2.2.10.0=/proc/boot/libstdc++.so
[type=link] /lib/libm.so.2=/proc/boot/libm.so
libm.so
[data=c]
#devc-sersci
setconf
# Executables must currently be below this line
# Include a console driver
devc-con
# Include pci server
pci-bios
seedres
# Network related items
libsocket.so
/etc/termcap=/etc/termcap
/etc/hosts=/etc/hosts
/etc/resolv.conf=/etc/resolv.conf
# Use the "public domain korn shell" as the default shell "sh"
sh=ksh
# Other executables
libcam.so
io-blk.so
cam-disk.so
fs-qnx4.so
pdebug
pipe
mqueue
devc-ser8250
devc-pty
devb-eide
ls
cat
ps
pidin
uname
/sbin/ifconfig
/sbin/route
/usr/bin/telnet
/usr/bin/ftp
/usr/bin/ping
/usr/sbin/qconn
# Include all the files for the default filesystems
libcam.so
io-blk.so
cam-disk.so
fs-qnx4.so
fs-dos.so
fs-ext2.so
cam-cdrom.so
fs-udf.so
# These programs need to be run only once from the boot image.
# "data=uip" will waste less memory as the RAM from the boot
# image will be used directly without making a copy of the data
# (i.e. as the default "data=cpy" does). When they have been
# run once, they will be unlinked from...
05/21/2010 2:09 PM
post55396
Does anyone know if it would suffice here?
On Wed, May 12, 2010 at 12:58:20PM -0400, Colin Burgess wrote:
> Sean just volunteered, I think :-)
> On 10-05-12 12:57 PM, Sean Boudreau wrote:
> > On Wed, May 12, 2010 at 11:59:25AM -0400, Elena Laskavaia wrote:
> >> 1) You can port Sun J2SE 1.5 on neutrino, because that is what latest needs
> > Would openjdk7 suffice?
> > -seanb
> > QNX Momentics Getting Started
> > http://community.qnx.com/sf/go/post54379
> cburgess@qnx.com
> http://community.qnx.com/sf/go/post54380
