Re: relocation R_MIPS_26 against 'fpadd' : recompile with -fPIC
02/16/2010 9:03 AM
post47366
Sunil Keshava wrote:
> Hello all,
> I am trying to compile a library in QNX 6.4.1. This library was previous built in QNX 6.2.1 and QNX 6.3. From what I
see, the all the files in the library are being compiled to create their *.o files. An error appears when the *.o files
are being used to created the library's *.so file. Here is the compilation error:
> C:\QNX641\host\win32\x86\usr\bin\ntomips-ld: FP32.o: relocation R_MIPS_26 against `fpadd' can not be used when making
a shared object; recompile with -fPIC
> FP32.o: could not read symbols: Bad value
> The FP32.o is the object file created for a 32 bit floating point library file FP32.s. The compiler says "recompile
with -fPIC". So I added -fPIC options to CCFLAGS of my project. However this did not help.
> I also searched the internet for a solution and in most places the solutions asked me to add the -fPIC option (which I
already tried).
> I really would appreciate it if anybody can provide a solution to my problem.
If your source file is an assembly file (FP32.s), passing -fPIC to the
compiler won't do any good because the compiler won't even be invoked.
If this is the case then your assembly has non-PIC code and will need to
be manually modified. If you're referring to FP32.s as an intermediate
file and you are invoking the compiler, please see if -mlong-calls makes
a difference.
Ryan Mansfield
