Forum Topic - relocation R_MIPS_26 against 'fpadd' : recompile with -fPIC: (4 Items)
Hello all,
I am trying to compile a library in QNX 6.4.1. This library was previous built in QNX 6.2.1 and QNX 6.3. From what I see
, the all the files in the library are being compiled to create their *.o files. An error appears when the *.o files are
 being used to created the library's *.so file. Here is the compilation error:
C:\QNX641\host\win32\x86\usr\bin\ntomips-ld: FP32.o: relocation R_MIPS_26 against `fpadd' can not be used when making a
shared object; recompile with -fPIC
FP32.o: could not read symbols: Bad value
The FP32.o is the object file created for a 32 bit floating point library file FP32.s. The compiler says "recompile with
 -fPIC". So I added -fPIC options to CCFLAGS of my project. However this did not help.
I also searched the internet for a solution and in most places the solutions asked me to add the -fPIC option (which I
already tried).
I really would appreciate it if anybody can provide a solution to my problem.
THanks
Sunil
Re: relocation R_MIPS_26 against 'fpadd' : recompile with -fPIC
Sunil Keshava wrote:
> Hello all,
see, the all the files in the library are being compiled to create their *.o files. An error appears when the *.o files
are being used to created the library's *.so file. Here is the compilation error:
a shared object; recompile with -fPIC
with -fPIC". So I added -fPIC options to CCFLAGS of my project. However this did not help.
 already tried).
If your source file is an assembly file (FP32.s), passing -fPIC to the
compiler won't do any good because the compiler won't even be invoked.
If this is the case then your assembly has non-PIC code and will need to
be manually modified. If you're referring to FP32.s as an intermediate
file and you are invoking the compiler, please see if -mlong-calls makes
a difference.
Ryan Mansfield
Thanks for the info Ryan.
FP32.S is an assembly file and not an intermediate file. When I look at the compilation log, I actually observer that
FP32.S is being compiled by GCC compiler and this creates the object file for FP32.S. So this should be mean that that
compiler options that I provide in my makefile should be applied while compiling this assemby file also right? Please
correct me if I am wrong.
I also tried the -mlong-calls option. This also did not help. I will see how I can modify the assembly code to eliminate
 the issue.
Sunil
No, it's only invoking the compiler to use the preprocessor. The
compiler is not generating any assembly code which is why compiler
options such as -fPIC and -mlong-calls have no effect.
eliminate the issue.
The code is likely doing something like:
j fpadd
when it needs to:
la t9,fpadd
jalr t9
You can use ntomips-objdump -r/-R to determine what part of your code is
generating the relocation.
Ryan Mansfield
