Forum Topic - QNX4 - editing sysinit for time zone change:
I have a QNX4 computer and want to change daylight saving time  rules in sysinit file.  I can edit the file but every
time I reboot  sysinit file  is replaced with the backup ones. How can I Make my changes to sysinit file permanent. OS
is on DiskOnChip.
Any help would be appreciated.
Selcuk Cagdas
RE: QNX4 - editing sysinit for time zone change
Are you editing the sysinit.$NODE file, where '$NODE' is your machine's
node number? The sysinit file doesn't get replaced at boot time.
From: Selcuk Cagdas [mailto:community-noreply@qnx.com]
Sent: Tuesday, April 14, 2009 1:39 PM
To: qnx4-community
Subject: QNX4 - editing sysinit for time zone change
sysinit file.  I can edit the file but every time I reboot  sysinit file
file permanent. OS is on DiskOnChip.
Selcuk Cagdas
QNX4 Community Support
http://community.qnx.com/sf/go/post26959
Re: RE: QNX4 - editing sysinit for time zone change
Thanks for the help. I checked the name of the file. There is no node number in the sysinit file name.  I also attached
the sysinit file if it helps.
> To: qnx4-community
> Selcuk Cagdas
Attachment: Text sysinit.txt 4.33 KB
RE: RE: QNX4 - editing sysinit for time zone change
Startrunning is not within the systinit file, so it won't inherit the
exported time zone. Is this what you problem is?
Sent: Tuesday, April 14, 2009 2:26 PM
To: qnx4-community
Subject: Re: RE: QNX4 - editing sysinit for time zone change
number in the sysinit file name.  I also attached the sysinit file if it
helps.
machine's
> To: qnx4-community
in
file
> Selcuk Cagdas
http://community.qnx.com/sf/go/post26969
Re: RE: RE: QNX4 - editing sysinit for time zone change
The sysinit file I attached is  already working. It has the old daylight time saving rule. I want to change it to new
one and make sure change is there when I reboot the computer. There is two directories called /sys1 and /sys2. Everytime
 I make changes sysinit file in /sys1, it is replaced one from /sys2.
> To: qnx4-community
> helps.
> machine's
> > To: qnx4-community
> in
> file
> > Selcuk Cagdas
RE: RE: RE: QNX4 - editing sysinit for time zone change
The QNX4 boot doesn't overwrite anything. The sinit program searches for
a /etc/config/sysinit.$NODE file and if it doesn't find one, it looks
for /etc/config/sysinit. I have no idea what you boot process is doing,
but it must be something that you are doing that is causing the file to
be overwritten.
Sent: Tuesday, April 14, 2009 3:15 PM
To: qnx4-community
Subject: Re: RE: RE: QNX4 - editing sysinit for time zone change
time saving rule. I want to change it to new one and make sure change is
and /sys2. Everytime I make changes sysinit file in /sys1, it is
> To: qnx4-community
it
> helps.
> machine's
> > To: qnx4-community
rules
> in
> file
sysinit
> > Selcuk Cagdas
http://community.qnx.com/sf/go/post26981
