Forum Topic - Process blocked (all threads) by devc-pty?: (3 Items)
A developer is encountering an issue wherein a BB10 process appears to be blocked for a period of several minutes.
No threads are responding. I added a heartbeat thread to log the status of threads every second, and captured thread
states pre-and post-block.
The process is an automated test framework to test that the installer is working by installing apps, such as Music Store
.  It receives instructions over PPS from another process, attempts an install and returns the results in the same
manner.  I'm relying on another user to reproduce this, as I cannot locally. The "result" seems to be successful (music
store installed), but the block time is excessive (6.5 minutes in this case).
Checking pidin on a subsequent run, we're seeing the following stats for the process:
    pid tid name               prio STATE       Blocked
62406885   1 ./InstallerApi      10r MUTEX       (0x80c2fcc) 62406885-03 #1
62406885   2 ./InstallerApi      10r SIGWAITINFO
62406885   3 ./InstallerApi      10r REPLY       4681795
Which seems to point to 4681795 as the culprit:
4681795   1 base/sbin/devc-pty  20r RECEIVE     1
which according to the docs is the pty (pseudoterminal?) manager.  I'm not sure if this is a wild goose chase, or is
accurate, and if so, why devc-pty would be completely blocking all process threads from executing.
Slog is attached.
Additional info
Thread status - Just before blocking (heartbeat from process log)
Tue Feb 11 07:14:59 2014 :: (1-Install)  :: INFO: Name: Main                tid: 1 flags: 0 why: 0 what: 0 ip: 18051888
sp: 133217656 stkbase: 132694016 tls: 133221984 stksize: 528384 tid_flags: 0        priority: 10 real_priority: 10
policy: 2 state: 6   syscall: 11 last_cpu: 0 timeout: 0        last_chid: -1 start_time: 1392102846808986439 sutime:
648628428   extsched:  reserved2: 7f0beb8
Tue Feb 11 07:14:59 2014 :: (1-Install)  :: INFO: Name: AI listener thread  tid: 2 flags: 0 why: 0 what: 0 ip: 18052880
sp: 134097396 stkbase: 133963776 tls: 134098528 stksize: 135168 tid_flags: 67108864 priority: 10 real_priority: 10
policy: 2 state: 11  syscall: 32 last_cpu: 1 timeout: 16779264 last_chid: -1 start_time: 1392102849108394360 sutime:
200430213   extsched:  reserved2: 7f0beb8
Tue Feb 11 07:14:59 2014 :: (1-Install)  :: INFO: Name: Work thread         tid: 3 flags: 0 why: 0 what: 0 ip: 18053992
sp: 134478776 stkbase: 134348800 tls: 134481920 stksize: 135168 tid_flags: 67239936 priority: 10 real_priority: 10
policy: 2 state: 12  syscall: 75 last_cpu: 0 timeout: 16781312 last_chid: -1 start_time: 1392102898768756582 sutime:
24172488    extsched:  reserved2: 7f0beb8
Thread status - Just after blocking (from app)
Tue Feb 11 07:21:30 2014 :: (1-Install)  :: INFO: Name: Main                tid: 1 flags: 0 why: 0 what: 0 ip: 18051888
policy: 2 state: 6   syscall: 11 last_cpu: 0 timeout: 0 last_chid: -1 start_time: 1392102846808986439 sutime: 667764981
Tue Feb 11 07:21:30 2014 :: (1-Install)  :: INFO: Name: AI listener thread  tid: 2 flags: 0 why: 0 what: 0 ip: 18053132
sp: 134030388 stkbase: 133963776 tls: 134098528 stksize: 135168 tid_flags: 67108864 priority: 10 real_priority: 10
policy: 2 state: 13  syscall: 80 last_cpu: 0 timeout: 0 last_chid: -1 start_time: 1392102849108394360 sutime: 204458961
Tue Feb 11 07:21:30 2014 :: (1-Install)  :: INFO: Name: Work thread         tid: 3 flags: 0 why: 0 what: 0 ip: 18051860
sp: 134477000 stkbase: 134348800 tls: 134481920 stksize: 135168 tid_flags: 67239936 priority: 10 real_priority: 10
policy: 2 state: 6   syscall: 11 last_cpu: 1 timeout: 0 last_chid: -1 start_time: 1392102898768756582 sutime: 66474342
 extsched: ...
Attachment: Text BrandonsSlog.log 2.39 MB
Re: Process blocked (all threads) by devc-pty?
Hi Andrew,
This is support forum for QNX 4.25 RTOS, not for BlackBerry. Please repost your question in suitable BlackBerry
Developer Forum:
http://supportforums.blackberry.com/t5/Developer-Support-Forums/ct-p/blackberrydev
10.03.2014, в 18:31:57, Andrew Mackie написал:
Store.  It receives instructions over PPS from another process, attempts an install and returns the results in the same
> Slog is attached.
> Additional info
18051888 sp: 133217656 stkbase: 132694016 tls: 133221984 stksize: 528384 tid_flags: 0        priority: 10 real_priority:
 10 policy: 2 state: 6   syscall: 11 last_cpu: 0 timeout: 0        last_chid: -1 start_time: 1392102846808986439 sutime:
18052880 sp: 134097396 stkbase: 133963776 tls: 134098528 stksize: 135168 tid_flags: 67108864 priority: 10 real_priority:
 10 policy: 2 state: 11  syscall: 32 last_cpu: 1 timeout: 16779264 last_chid: -1 start_time: 1392102849108394360 sutime:
18053992 sp: 134478776 stkbase: 134348800 tls: 134481920 stksize: 135168 tid_flags: 67239936 priority: 10 real_priority:
 10 policy: 2 state: 12  syscall: 75 last_cpu: 0 timeout: 16781312 last_chid: -1 start_time: 1392102898768756582 sutime:
667764981  extsched:  reserved2: 7f0beb8
18053132 sp: 134030388 stkbase: 133963776 tls: 134098528 stksize: 135168 tid_flags: 67108864 priority: 10 real_priority:
 10 policy: 2 state: 13  syscall: 80 last_cpu: 0 timeout: 0...
Thread one is blocked on a mutex currently locked by thread 3:
thread 3 didn't unlock before asking work of devc-pty (read(),
write() etc...).  Thread 2 is probably blocked in poll() or
select().  A backtrace of all the threads will be more definitive.
BTW this isn't a qnx4 question.
On Tue, Mar 11, 2014 at 12:53:19PM +0400, Олег Большаков wrote:
> Hi Andrew,
Developer Forum:
> Respectfully,
> Oleg
> > Slog is attached.
> > Additional info
18051888 sp:...
