03/03/2010 9:29 AM
post48704
I am creating custom widgets and found that when testing these widgets, I noticed that the draw order has an effect on
some widgets.
The widgets are updated every 1/2 second via a callback from a PtTimer.
So this is the problem. I created 5 custom widgets. I can add all 5 custom widgets to a window module and build and
run the application. Depending on the draw order of these widgets, only certain widgets will appear. Those that do not
appear will appear after I force a redraw (damage the widget).
So lets say widget number 5 is causing this problem. If the draw order is 1 - 2 - 3 - 4 - 5, all widgets will appear.
If the draw order is 4 - 2 - 5 - 3 - 1, widgets 3 and 1 will not be drawn until I force a redraw. Widgets 4, 2 and 5
will appear.
Right now I have 2-ish work arounds:
1. Always place widget 5 in a PtDBContainer (only 1 per PtDBContainer) and
2. Always draw widget 5 last, however, this still corrupts the widgets - so this really isn't a work-around.
Neither of these are a good option for me. Has anyone experienced this? Could anyone offer some advice to help solve
this problem?
Chris
