Forum Topic - Rhapsody, QNX, and Photon Application Builder: (2 Items)
Hello All,
I am using IBM/Telelogic Rhapsody (v 7.5) together with QNX (v 6.4.1) for a development of a new application. The
application will have a GUI which I would like to create with the Photon Application Builder. Does anyone have
experience developing applications with Rhapsody and PhAB? What is the recommended way to communicate between the two
processes? The User of the application should be able to enter information via the GUI as well as see run time control
data on the GUI. Or is it recommended to program the GUI without the PhAB and to call the Photon library functions
directly from the Rhapsody Model/code? It would be nice to have a solution using the PhAB since it greatly simplifies
the creation of Windows and their layout.
Thank you for you help
Cheers
Marcel
Re: Rhapsody, QNX, and Photon Application Builder
Hi !
We also firstly planned to use photon with Rhapsody and QNX. As Photon provide C source code, it is possible to generate
 a resource manager that will be called by the main application (generated by Rhapsody). You can also share memory
between the two applications to exchange data. At first sight, it appears difficult to generate photon code in Rhapsody
(you need to design a wrapper class for Photon functions).
Finally we decided to use Qt which is now proviced with LGPL licence, graphic application and main application will
communicate each-other using TCP/IP communication trough local loopback.
