Re: QNX 6.6 configuring two network interfaces
06/29/2017 7:55 AM
post117834
First of all, you must make sure that each interface is on a separate
network. If you want the dhcp.client on the first interface then run
dhcp.client -iwm0
You can then ³ifconfig wm1 192.168.1.20²
Second, if you want to run dhcp.client on both interfaces, you can use the
³-iwmn² on each interface, where ¹n¹ in the interface number.
On 2017-06-29, 4:53 AM, "Alan Bontoft" <community-noreply@qnx.com> wrote:
>I am trying to configure two network interfaces on a 6.6 system. Both
>are identical Intel devices. Ideally I would like to use DHCP on the
>first interface and a Static IP on the second but I can get away Static
>IPs on both if need be.
>If someone could post a 'bare minimum' network_start script as a starting
>point it would be most helpful.
>I've got as far as getting both interfaces working but if I use the
>following:
>it seems to ignore the static IP and grab one from dhcp instead.
>Thanks in advance
>Alan
>General
>http://community.qnx.com/sf/go/post117833
>general-community-unsubscribe@community.qnx.com
