Forum Topic - Want my .so libraries to be loaded run time: (2 Items)
Hi, I am recently started using QNX IDE for my work. Here i have a new module in .so lib format and also i have test app
 to test my lib. Bu whenever i start my test app in debug mode,i am able to keep breakpoints in t the code that
corresponds to my test app, but where as if try setting brk point in my driver code, then i see below error "No source
file named  XXXXX.c". then when i open the module list i see the my test app in loaded state where as my.so lib in not
loaded state. Can you help what i need to do so that the lib also always gets loaded?
Srinivas
Re: Want my .so libraries to be loaded run time
You have do some fiddling with debugger to enable debugging of shared
libraries see
http://community.qnx.com/sf/wiki/do/viewPage/projects.ide/wiki/DebuggerFAQ
app to test my lib. Bu whenever i start my test app in debug mode,i am able to keep breakpoints in t the code that
> Thanks
> Srinivas
> http://community.qnx.com/sf/go/post94255
> To cancel your subscription to this discussion, please e-mail general-community-unsubscribe@community.qnx.com
