Forum Topic - resource manager performance:
I am just porting some real-time control software to qnx. I would like to use resource managers for interfacing the
actual controller code with hardware-io (driver) code. However,  performance is very important for my application.
That's why I'm wondering how using a resource manager compares with using other IPC methods (e.g. message queues)
performance-wise.
Typical read/write sizes would be only a few bytes, but there are several reads and writes every msec. I guess the
question is, how high is the overhead of using the resource manager framework compared to native message passing?
Any help would be greatly appreciated.
Thomas
RE: resource manager performance
> From: Thomas Buschmann [mailto:buschmann@amm.mw.tum.de]
> Sent: October 31, 2007 5:42 PM
> To: general-community
> Subject: resource manager performance
> performance-wise.
> are several reads and writes every msec. I guess the question
A resource manager is really just a (relatively) thin layer on
top of the native messaging.  It provides a bit of a handshaking
and authentication framework on top of the standard messaging
API as well as a set of standardized messages (ie read/write).
Once you have established a connection to your resource manager,
(via open) the fd you work with is the same as a coid that you
would have received if you had done a ConnectAttach().
When you read/write on that fd, it is equivalent to performing
a MsgSend with a standard message header.  You can see the read/write
implementation here:
http://community.qnx.com/integration/viewcvs/viewcvs.cgi/trunk/lib/c/1/read.
c?root=coreos_pub&rev=153052&system=exsy1001&view=markup
Depending on what else you are doing in your system, performing
hundreds or thousands of single byte read/writes every second
is really not very efficient.  You can do it, and the limiting
factor is going to be the speed of your CPU and the frequency
of the operations, but you might want to look at different
alternatives.
One alternative is the mq library that uses the asynchronous
messaging framework.  There is also an mqueue service that uses
standard message passing, but your own custom resource manager
will be more efficient in that case.
Alternatively to that, it might be more worthwhile for the
application to create a shared memory area that the server and
clients can all access.  It depends on what is being done with
the data.
To get a feel for the overhead, you can use the instrumented kernel
and the system profiler tooling to see what is going on in the
system and measure some of the typical latencies.
Hope this helps,
 Thomas
Thanks for detailed response. Probably the only way to know what the
overhead is for a specific application is to time it, which is what I'll
do. Thanks again!
Thomas
Am Freitag, den 02.11.2007, 08:42 -0400 schrieb Thomas Fletcher:
> > performance-wise.
> alternatives.
> the data.
> Hope this helps,
>  Thomas
> http://community.qnx.com/sf/go/post2408
Dipl.-Ing. Thomas Buschmann
Technische Universitaet Muenchen
Lehrstuhl fuer Angewandte Mechanik
Boltzmannstrasse 15, D-85747 Garching
Phone: +49 89/289-15221
Fax  : +49 89/289-15213
eMail: buschmann@amm.mw.tum.de
WWW  : http://www.amm.mw.tum.de/People/buschmann.html
