| wiki2579: SDP_6.4.0_BSP_Info (Version 47) |
SDP 6.4.X BSP Information#This page contains important information required to compile and package BSPs with the QNX Software Development Platform 6.4.0 and 6.4.1 . The release number ( e.g. 6.4.1 ) will be referred to explicitly if instructions are applicable only to the stated release; otherwise 6.4.x will be used. BSP Source Guide (for QNX 6.3.x and 6.4.x BSPs)#http://community.qnx.com/sf/wiki/do/viewPage/projects.bsp/wiki/Bsp_source_guide
What's New #6.4.1#
6.4.0#
6.4.0 and 6.4.1 Interoperability #Building 6.4.0 BSPs with QNX SDP 6.4.1 #6.4.0 BSPs should compile and work with QNX SDP 6.4.1.NOTE: 6.4.0 BSPs for e500-based boards cannot be used with SPE turned ON; you must use 6.4.1 versions of these BSPs instead Building 6.4.1 BSPs with QNX SDP 6.4.0#This is not supported, and upgrading to SDP 6.4.1 is required. NOTE: New BSPs will be delivered under 6.4.0 unless 6.4.1 is strictly required e.g. PPC-SPE.
Available BSPs#Here is a list of available BSPs: 6.4.1 BSPs#6.4.0 BSPs#
A complete list of BSPs can be found here. Building 6.4.x BSPs#Importing and Building a BSP live from Foundry 27 (using IDE 4.6)#
Importing and Building a BSP archive with the IDE (using IDE 4.6)#
NOTE: BSPs downloaded from Foundry27 are sometimes double zipped (when downloading by pressing the download button as opposed to using your browser "download" functionality over links). When this happens, make sure to unzip the first level of archive before importing into the IDE. This will be resolved in future release of the IDE (Ref# 68666). Importing and Building a BSP archive with the IDE (using IDE 4.5)#
NOTE: BSPs downloaded from Foundry27 are sometimes double zipped (when downloading by pressing the download button as opposed to using your browser "download" functionality over links). When this happens, make sure to unzip the first level of archive before importing into the IDE. This will be resolved in future release of the IDE (Ref# 68666). How to use the 6.4.0 tool chain within IDE 4.6 ( which is shipped with SDP 6.4.1) #Newer QNX Neutrino 6.4.0 BSPs will require the use of IDE 4.6. TestPrerequisite: Both QNX SDP 6.4.0 and QNX SDP 6.4.1 must be installed.
Building BSPs at the command line#
Resources#
