wiki1230: Memmgr_source_guide | ||||||||||||
Quick Guide to the Memory Manager Source#
Where is the source?#
What are the good bits?#
Overview#Though the OS is written in C, the memory manager implementation supports an object-oriented concept: polymorphism. There is a global variable called memmgr that defines an API to the memory manager. The type of the object is struct memmgr_entry, which defines a few data fields and a whole bunch of functions. Throughout the code we make a lot of references to the memmgr variable. For example, when we need to change address spaces we call memmgr.aspace(). But what's behind the memmgr variable? It could be any of a couple of different memory manager implementations. In practice, it's always the virtual memory manager (implemented in services/system/memmgr/vmm*.*) but it's possible that it could be the physical memory manager (services/system/memmgr/pmm*.*) or the runtime-executive memory manager (services/system/ker/emm*.* and services/system/ker/smm*.*). When the system initializes, one of those memory managers is assigned to the memmgr variable (have a look at the init_memmgr() function at the end of memmgr_init.c). As I said, in practice it's always the virtual memory manager but the others are possible. But when you're looking at the kernel code and you see something like a call to memmgr.foo(), you can assume that memmgr.foo() is implemented with vmm_foo(). For a more detailed look at the design of the memory manager, refer to Virtual memory manager data structures and Virtual memory manager algorithms. |
