qin zhou
05/15/2012 1:39 AM
post93077
hello ,i'm new to qt/qnx.i encounter a problem when i run qtdemo .the host is momentics on the winxp,and the target is
neutrino on vmware .
i do that following the steps showing below:
1) Launch button/Logout/End Photon session ... will exit photon to text mode.
2) Login. Run "ifconfig" and determine IP address.
3) Telnet into the IP address from a different host.
4) From telnet, run '/usr/photon/bin/devi-hid -Pr kbd mouse'
5) From telnet, run 'qtdemo -qws' ... graphics should appear on console
from the terminal ,it shows
QQnxScreen: Attached to Device, number of displays: 1
QQnxScreen: Attached to Display 0, resolution 1024x768, refresh 60 Hz
but from the vmware ,mouse and keyboard are still no response
the relevant topic http://community.qnx.com/sf/go/projects.qt/discussion.general.topc19765,but i fail,please help me
Dennis Kellly
Re: unable to execute qtdemo
Dennis Kellly
05/15/2012 9:48 AM
post93086
Did you use this image for VMware? It includes the VMware video driver.
http://www.qnx.com/download/feature.html?programid=21189
You can check the driver and mode being used by launching Photon, then Configure/Display.
Apparently, 32K colors (15-bits + 1-bit alpha) does not work w/Qt as reported here: http://community.qnx.com/sf/
discussion/do/listPosts/projects.qt/discussion.general.topc20436?pageSize=-1#post_post89523
qin zhou
回复: Re: unable to execute qtdemo
qin zhou
05/15/2012 10:58 AM
post93093
this is the screenshot,as you see,i cannot change the color mode ,i will show you what i have done for now to make qt
run on the qnx/based on vmware
1)i copy from C:\QNX650\target\qnx6\x86\usr to 192.168.149.131:\usr
2)in the process ,there is two warnings that appears,but i ignore ,they are
3) From telnet, run '/usr/photon/bin/devi-hid -Pr kbd mouse'
4) mouse/keyboard still no response
i doubt if there is something wrong with io-hid,i refer the document
(devi-hid title )
,so i run io-hid first. i do the following:
1)io-hid -dusb -dps2ser ps2mouse:mousedev:msoft:uart,1:kbd:kbddev &, it shows
2)/usr/photon/bin/devi-hid -Pr kbd mouse
3)qtdemo -qws
fail
2012-05-15
qhzbit
发件人:Dennis Kellly
发送时间:2012-05-15 21:41
主题:Re: unable to execute qtdemo
收件人:"general-qt"<general-qt@community.qnx.com>
抄送:
Qt General
http://community.qnx.com/sf/go/post93086
To cancel your subscription to this discussion, please e-mail general-qt-unsubscribe@community.qnx.com
qin zhou
qin zhou
05/15/2012 11:57 AM
post93096
4)qtdemo -qws
fail,i don't know the output from the QQnxScreen means
2012-05-15
qhzbit
发件人:Dennis Kellly
抄送:
Qt General
2012-05-15
qhzbit
发件人:Dennis Kellly
抄送:
Qt General
Dennis Kellly
Re: 回复: Re: unable to execute qtdemo
Dennis Kellly
05/15/2012 11:48 AM
post93098
These are "normal" messages... not errors.
But you should see two more lines like
QQnxMouseHandler: connected.
QWSQnxKeyboardHandler: connect
Have you set the environment variables?
QWS_DISPLAY=qnx
QWS_KEYBOARD=qnx
QWS_MOUSE_PROTO=qnx
qin zhou
回复: Re: 回复: Re: unable to execute qtdemo
qin zhou
05/15/2012 10:15 PM
post93120
thank you ,i make it ,before /usr/photon/bin/devi-hid -Pr kbd mouse,i add # export QWS_DISPLAY=qnx
# export QWS_MOUSE_PROTO=qnx
# export QWS_KEYBOARD=qnx, and i make it ,thank you !
i have another question ,now i want to make my own app .my host is winxp ,my target is vmware on this xp .i have read
readme.txt(which is included in the attachment),i do as the following steps:
1)enter C:\Qt\hello,and create a makefile including "LIST=OS CPU VARIANT
MAKEFILE=GNUmakefile
include recurse.mk
##eof"
2)Inside the same directory, create subdirectories called nto-x86-o,including "GNUmakefile"
ifndef QCONFIG
QCONFIG=qconfig.mk
endif
include $(QCONFIG)
include $(MKFILES_ROOT)/qmake-qt.mk
##eof
3)from cmd prompt,i enter the C:\Qt\hello,and run make ,but it shows
4)so i enter the ksh ,and run make
2012-05-16
qhzbit
发件人:Dennis Kellly
发送时间:2012-05-15 23:40
主题:Re: 回复: Re: unable to execute qtdemo
抄送:
QWS_DISPLAY=qnx
QWS_KEYBOARD=qnx
QWS_MOUSE_PROTO=qnx
Qt General
http://community.qnx.com/sf/go/post93098
qin zhou
qin zhou
05/15/2012 10:48 PM
post93121
following the last email ,i try as a pdf called qmake_qnx.pdf
1)i copy the bat file to
C:\qnx650\host\win32\x86\usr\bin\qmake_qnx.bat
2)run qmake_qnx i386
3)i ignore the error,and copy it to the target ,./cEasy -qws ,it shows
2012-05-16
qhzbit
发件人:Dennis Kellly
抄送:
QWS_DISPLAY=qnx
QWS_KEYBOARD=qnx
QWS_MOUSE_PROTO=qnx
Qt General
qin zhou
05/17/2012 9:33 PM
post93171
hello ,i'm new to qt/qnx,now i encounter a question ,that is how i run my own qt app on the target based on qnx (my host
is
winxp,and target is vmware).i don't really know how it works, i guess:
1)the first step : i make a project by qt-creator and run ,debug to make sure it will run well.
2)the second step : i make the resource that is needed to run on qnx again .
According to this thought,i did the following things:
1)first i create a project "hello world" in the qt-creator ,and it works well
2) as the "read me"says,i enter C:\Qt\hello,and create a makefile including
include recurse.mk
##eof"
3)Inside the same directory, create subdirectories called nto-x86-o,including "GNUmakefile"
ifndef QCONFIG
QCONFIG=qconfig.mk
endif
include $(QCONFIG)
##eof
4)from cmd prompt,i enter the C:\Qt\hello,and run "make" ,but it shows mingw32-make is Not internal or external command
also not be operation of the procedure or a batch file.
5)so i enter"ksh",run "make",it shows errors as the attachment shows ,but it produce a .project and a hello file.so i
transfer the hello file to the vmware ,the app absolutely failes to run .
another question ,i know that qt can be intergrated with eclipse which makes the developer convenient,however, can it
be
intergrated into the momentics (run and debug in the momentics environment)?
thank you ,and I look forward to your reply
2012-05-18
qhzbit
发件人:Dennis Kellly
抄送:
QWS_DISPLAY=qnx
QWS_KEYBOARD=qnx
QWS_MOUSE_PROTO=qnx
Qt General
