Forum Topic - Siemens IPC 677C: (5 Items)
Siemens IPC 677C
We have purchased a Siemens Simatic IPC 677C unit and have loaded QNX4.25 using the 2011 Product suite.
We are having a problem with the graphics driver.
I have attached some diagnostic information from the machine.
Any ideas?
Pete Mackereth
Attachment: Compressed file ToQNX.zip 172.39 KB
Re: Siemens IPC 677C
Hello, Pete!
Please try to use Pg.intelhd graphics driver.
/etc/config/trap/crt.<NODE>:
Null.ms;Pg.intelhd -g1280x1024x32 -d0x8086,0x46 -I0 -HNqnx/crt;
Andrey
Attachment: Text Pg.intelhd.20120221.tar.gz 107.29 KB
Hi Andrey,
Thanks for your quick response and suggestion.
I've tried the new Pg.intelhd driver with a setting of 1024x768x32 but there is still a problem, I've attached a screen
that shows the issue.
Pete
Attachment: Image 20140731_114036.jpg 3.4 MB
Hello, Pete!
Is it possible that your application use different color depth?
Do you have the same issue with Pg.flatdc32 and Pg.vga4 (visually)?
Andrey
Hi Andrey,
I have tried Pg.flatdc32 and it works ... thank you for your help!
Pete
