Forum Topic - pf.conf: (1 Item)
pf.conf
Hi all,
I have a problem in my system with qnx 6.4.
My system has more interfaces:
en5 = this is connected to my router (192.168.0.1) which gives it the ip 192.168.0.100
uap0 = wireless interfaces which has ip 192.168.1.X
The wireless interface can be work only in ap mode and not client mode.
I can connect my phone to uap0 and it gives me the ip 192.168.1.100
I'd like to be able to route wireless traffic to interface en5 to be able to go to internet with my phone.
I suppose that I have to work with nat rules but I have a problem because actually it doesn't work.
In my system the variable
net.inet.ip.forwarding=1
and my pf.conf is the following:
[code]
int_if = "en5"
icmp_types = "echoreq"
broadcast_add = "255.255.255.255/32"
# scrub
scrub in all no-df
# outgoing connections on MOST must not exceed 968 segmentsize (MTU 1008 total)
scrub out on mam0 max-mss 968
# Skip all PF filtering on lo0
set skip on lo0
### NAT/redirection rules
### table name has to be used in SW to alter table
table <natRangeTable> { 192.168.1.0/24, 10.0.0.101 }
nat on ppp0 from <natRangeTable> to any -> (ppp0)
nat on en5 from <natRangeTable> to any -> (en5)
nat on uap0 from 192.168.1.0/24 to any -> (en5)
# DNS redirect rules
rdr-anchor dnsRedirect1
rdr-anchor dnsRedirect2
rdr-anchor dnsRedirect3
rdr-anchor dnsRedirect4
### filter rules
pass out keep state
pass in quick on mam0 keep state
pass in quick on mep0 keep state
pass in quick on mhp0 keep state
pass quick on uap0 from 192.168.1.0/24 to 192.168.1.1
pass in quick on uap0 keep state
pass in quick on $int_if keep state
#block in on uap0
block in quick on uap0 from any to (mam0:network)
block in quick on uap0 from any to (mhp0:network)
block in quick on uap0 from any to (ppp0)
#block in quick on uap0 from any to (en5:network)
# pass through DHCP from WLAN to DHCP server
pass in quick on uap0 proto udp from any port bootpc to $broadcast_add port bootps keep state
pass in quick on uap0 to $broadcast_add keep state
# pass in SSDP messages (out is not blocked)
pass in quick on uap0 proto udp from any to 239.255.255.250 port 1900 keep state
# let our http server on 8100 for UPnP be reachable
pass in quick on uap0 proto tcp from any to any port 8100 keep state
pass in quick on uap0 from any to 224.0.0.0/4 keep state
pass in quick on uap0 proto udp to (uap0) port 49152:65535
# use external traffic from WLAN as trigger for dial-up
anchor dialUpTrigger
pass in quick inet proto icmp all icmp-type $icmp_types keep state
[/code]
and my ifconfid is the following:
[code]
pflog0: flags=100<PROMISC> mtu 33192
mam0: flags=843<UP,BROADCAST,RUNNING,SIMPLEX> mtu 1008
    address: 00:00:00:00:01:00
    inet 10.0.0.100 netmask 0xffffff00 broadcast 10.0.0.255
mhp0: flags=842<BROADCAST,RUNNING,SIMPLEX> mtu 1500
en5: flags=80008a43<UP,BROADCAST,RUNNING,ALLMULTI,SIMPLEX,MULTICAST,SHIM> mtu 1500
    address: 00:80:c8:3c:77:7e
    media: Ethernet 10baseT full-duplex
    status: active
    inet 192.168.0.100 netmask 0xffffff00 broadcast 192.168.0.255
uap0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> mtu 1500
    address: 00:1c:d7:25:20:89
    media: <unknown type> autoselect
    inet 192.168.1.1 netmask 0xffffff00 broadcast 192.168.1.255
    link 00:00:00:00:00:00
[/code]
The output of pfctls -s all is:
[code]
TRANSLATION RULES:
nat on ppp0 from <natRangeTable> to any -> (ppp0) round-robin
nat on en5 from <natRangeTable> to any -> (en5) round-robin
rdr-anchor "dnsRedirect1" all
rdr-anchor "dnsRedirect2" all
rdr-anchor "dnsRedirect3" all
rdr-anchor "dnsRedirect4" all
FILTER RULES:
scrub in all no-df fragment reassemble
scrub out on mam0 all max-mss 968 fragment...
