Forum Topic - Sending Packets on different tcp/ip stacks: (15 Items)
Hi all,
I installed qnx 6.4.0 and my machine has two ethernet interfaces (en0 and en1). I checked /dev it has io-net directory
which contains(en0 and en1).I am able to ping to other machines on both eth interfaces.
I have doubt why the directory name is io-net instead of io-pkt because io-pkt-v4-hc is running.
I tried to initaite second instance of tcp ip stack with the following command
io-pkt-v4-hc -i1 -dpcnet pci=0x1 -ptcpip prefix=/sock2
[My Nic are AMD ]
then i checked /dev directory there was no io-net1
(dir which should contain en0 and en1 so i can configure this tcpip stack to en1 using
SOCK=/sock2 ifconfig en1 up) and ping to other machine using this second stack.please let me know the solution.
thanks
RE: Sending Packets on different tcp/ip stacks
Hi Rahul:
   What you are seeing under /dev is the entry for the io-net legacy style driver that is being run.  Native io-pkt
drivers don't create /dev entries.  In terms of your second stack, you can't have two stacks sharing the same interface.
  If your first stack is already using both ethernet NICs, the second stack won't be able to access them.  You need to
change the way that the first stack is being run to only use a single interface if you want the second interface to be
used by a second stack.
Checking /dev isn't the best way to find out what interfaces the stack is using, by the way.  ifconfig is the correct
utility to use for this.
   Robert.
From: RAHUL SABLE [mailto:community-noreply@qnx.com]
Sent: Wed 1/28/2009 6:58 AM
To: ionetmig-networking
Subject: Sending Packets on different tcp/ip stacks
Hi all,
[My Nic are AMD ]
thanks
io-net migration
http://community.qnx.com/sf/go/post20904
Attachment: Text winmail.dat 3.28 KB
Re: RE: Sending Packets on different tcp/ip stacks
Hi Robert,
  In which starting script they are initiating default (io-pkt) tcp-ip stack.How we can modify that script so defualt
stack will use only eno(one interface) ?
How we can bind the tcp/ip stack to use specific ethernet interface.
beacuse there is no option to bind a tcp/ip stack with specific eth interface.I am using below command to initiate the
second stack please correct me if i am wrong.I tried passing mac address of eth1 in this command.
io-pkt-v4 -i1 -dpcnet pci=0x1 -ptcpip prefix=/sock2
RE: RE: Sending Packets on different tcp/ip stacks
> How we can modify that script so defualt stack will
I would just slay the original stack, and restart
two stacks, the way you want them.
> ethernet interface.
That's all a matter of how you start the driver.
You're on the right track with the pci option.
Start one driver in one stack with "pci=0" and
the other driver in the second stack with "pci=1".
aboyd
Re: RE: RE: Sending Packets on different tcp/ip stacks
I slayed io-pkt-v4-hc which was intiated default by qnx .Then I executed the following cmd to start first intance.
io-pkt-v4-hc -dpcnet pci=0h  -ptcpip
for second instance
io-pkt-v4-hc -i1 -dpcnet pci=1h -ptcpip prefix=/sock2
then i have given ifconfig I saw only en0 interface according to previous reply  I should see both interfaces.
thanks
Rahul
> for second instance
# ifconfig               <- should show 1
# SOCK=/sock2 ifconfig   <- should show the other
RE: RE: RE: Sending Packets on different tcp/ip stacks
Side note to this, I don't think that "0h" is valid although it may be
working.  "0x0" is valid, "0" is valid, but   the "h" is probably just
being ignored.
From: Sean Boudreau [mailto:community-noreply@qnx.com]
Sent: Wednesday, January 28, 2009 1:00 PM
Subject: Re: RE: RE: Sending Packets on different tcp/ip stacks
> for second instance
io-net migration
http://community.qnx.com/sf/go/post20942
Right - strtoul() is used in the common mii lib
to parse the pci=X option (pci device index) and
I don't think it understands the trailing "h" which
actually isn't required.
Just stick with "pci=0" and "pci=1"
If you really need to specify a hex value,
do it with a prefixed zero x or X: "0x1" or
"0X1" which are both decimal 1 (one).
A bare prefixed zero indicates an octal value
follows.  Not many people need octal any more.
aboyd
Re: RE: RE: RE: Sending Packets on different tcp/ip stacks
Hi all,
I tried the following things and the results are
First i slayed default io-pkt-v4-hc
then i configured the first tcp ip stack with pci
#io-pkt-v4 -dpcnet pci=0
for second instance
#io-pkt-v4 -i1 -dpcnet pci=1 -ptcpen0ip prefix=/sock2
#ifconfig
lo0: loop back inteface
en0: <mtu etc >
        address 00:0c:29:28:ff:dd
#SOCK=/sock2 ifconfig
en0: <mtu etc >
        address 00:0c:29:28:ff:e7
I have seen here the mac addresses are different may be they are binding to the different ethernet interfaces but when i
 tried to assign ip addresses I got the following errors
#ifconfig en0 192.168.1.5 up
ifconfig:SIOCGIFLAGS en0:No such device or address
#SOCK=/sock2 ifconfig en0 192.168.2.5 up
and i also  verified /dev/io-net and /dev/io-net1
both has en0 interfaces. Please let me know where i am wrong
thanks
RE: RE: RE: RE: Sending Packets on different tcp/ip stacks
> for second instance
I hope that's a typo - that should be "-ptcpip" above,
not "-ptcpen0ip".
I'm puzzled by what you see - you say that (eg first
invocation) "ifconfig" shows the interface, but
"ifconfig en0" fails?  That message generally means
that it can't find the stack at all - usually, it's
simply not running.
P.S.  Be sure, before you start io-pkt, that you have
killed off all previous copies of it!  ie
  # pidin | grep io-pkt
should come up empty.
aboyd
Re: RE: RE: RE: RE: Sending Packets on different tcp/ip stacks
Hi Andrew,
 The second one typo error it was -ptcpip.I ensured that no io-pkt-v4-hc was running coz i have given the slay commnad
for io-pkt-v4-hc twice. second time it was giving unable to find the process(io-pkt-v4-hc).
As you said i slayed io-pkt-v4-hc and then started tcp/ip stacks.Do you see any mistake in my commands. My requirement
is simple i have 2 nic cards(ethernet interfaces) and i want to intiate two tcp ip stacks one should bind with en0 and
other should bind with en1. and then i want to ping to other machines as bleow.
on default stack without prefix
#ping ipadress
on second instance with prefix
#SOCK=/sock2 ping ipaddress
Please let me know where i am going wrong.
RE: RE: RE: RE: RE: Sending Packets on different tcp/ip stacks
> My requirement is simple i have 2 nic cards
> and other should bind with en1
Close.  Both stacks will have an "en0" - there
will be NO en1.
Your invocations of io-pkt look good to me -
many of us here at QNX run multiple stacks,
often even mixtures of io-net and io-pkt.
Can you paste the output of "pci" here?
Thx,
aboyd
One tip for you:  when I run multiple stacks,
I usually do it with different hardware:  eg
one speedo card, one i28544.  So, each stack
runs a different driver.  This keeps my life
simple.  You can do it with two nics of the
exact same type, but it's easier to get things
confused, especially if it's the first time
you've ever run more than one stack at the
same time.
aboyd
Hi all,
 Everything is working fine.Now i am able to send the data on both stacks.I was confused because it was showing en0 in /
dev/io-net and /dev/io-net1.Thanks for the suggestions.
Rahul
The ifconfig (SIOCGIFLAGS) failure looks suspicious. What does nicinfo
say?
Weijie
Sent: January 29, 2009 1:42 AM
Subject: Re: RE: RE: RE: Sending Packets on different tcp/ip stacks
Hi all,
for second instance
#ifconfig
en0: <mtu etc >
en0: <mtu etc >
to the different ethernet interfaces but when i tried to assign ip
thanks
io-net migration
http://community.qnx.com/sf/go/post20970
