Forum Topic - Duplicate packets and foward into two NIC: (8 Items)
I try to duplicate packets and foward into two NIC using pfil, the source code as follow. But the pfil can't catch
ethernet header. Is any one help me how can catch ethernet header using pfil.
Attachment: Text portmirror140206.rar 632.23 KB
Re: Duplicate packets and foward into two NIC
See the support ticket for a response.
> http://community.qnx.com/sf/go/post108826
> To cancel your subscription to this discussion, please e-mail general-networking-unsubscribe@community.qnx.com
I am interesting in this topic, too
The attached jpgs shows that the duplicated outgoing packet did not include the source Ethernet MAC address of the 2nd
interface. It is very strange situation that the Ethernet driver did not prefix MAC and pass it out directly.
Does the pfil of QNX is 100% equal to FreeBSD?
The issue was that in the sample provided there's an expectation that
the full frame was being passed to the output hook in this particular
case the IP packet was in the mbuf, need to set AF_INET and to set the
destination IP address so the stack resolves it and prepends the
ethernet header prior to sending the packet. See the attached sample.
Attachment: Text portmirror.c 6.55 KB
The pointer *p address null, so the program crash. What should I write for this pointer? Take destination ip 192.168.1.1
 for example, how to fill-in this p pointer? Or, do you mean take ip from output_hook mbuf?
My patch missed a line:
Add p = mtod(m1, char*); after line 89 (memset()). I have updated the
support ticket with this same response. See attached file which has the
correct patch.
Sorry about that.
.1 for example, how to fill-in this p pointer? Or, do you mean take ip from output_hook mbuf?
> http://community.qnx.com/sf/go/post108966
Attachment: Text portmirror.c 6.57 KB
Use new program to send  two NIC  is OK now. But when I break the original line, the mirror line also stop to work. I
hope when i break the original line , the mirror line can still transmit. How can i do?
I am not sure I understand what you are asking, but I attached and
updated and simpler version of the port mirroring module. Again it is
provided as-is, but it works a lot better than my initial version.
> http://community.qnx.com/sf/go/post110211
Attachment: Text mirror.c 3.21 KB
