Liam Howlett
Strange library loading issue
Liam Howlett
11/12/2009 4:36 PM
post41871
I have a library that one of my processes can't seem to find. It's intermittent and so I'm not sure when I change
something that I solved the route problem or just lucked out during the build. Here is the runtime issue:
# export DL_DEBUG=1
# export LD_LIBRARY_PATH=/proc/boot
# ls -la /proc/boot/liboamlib.so.1
-rwxrwxr-x 1 508 508 446464 Nov 12 2009 /proc/boot/liboamlib.so.1
Process 368664 (ls) exited status=0.
# dbs
load_object: attempt load of liboamutilities.so.1
load_elf32: loaded lib at addr fe378000(text) fe38ac70(data)
load_object: attempt load of libcommonSlSwLogLib.so.1
load_elf32: loaded lib at addr fe38c000(text) fe39b4e0(data)
load_object: attempt load of libutilities.so.1
load_elf32: loaded lib at addr fe39d000(text) fe3b4710(data)
load_object: attempt load of liboamlib.so.1
load_elf32: mmaped, addr 0 67c80 vaddr fe41ec80
Could not find library liboamlib.so.1
Process 376856 (dbs) exited status=1.
As you can see the library is in /proc/boot and the LD_LIBRARY_PATH is set to the correct location. Why is it mmaping
some strange memory location? pidin mem does not show liboamlib in memory anywhere.
Any ideas would be helpful at this point, I am running low myself.
would the gid/uid be an issue?
This is cross compiled on linux x86 for ppcbe
Liam
