Forum Topic - RamDisk and wifi network driver: (3 Items)
Hello.
So I have wifi working on my board TI AM335x with the TI/QNX driver.  I have followed all instructions and it is all
working.
The thing I'm doing (and I think this is wrong) is that I startup the "io-pkt-v4-hc -dasix" running and then I start
some of my applications.  These applications setup listening ports on the loopback device.
When I startup the ramdisk and then startup the new io-pkt-v4-hc -dti127x-am335x driver my loopback interface is created
 new.
netstat shows me none of my listening ports on the loopback interface.
I'm not sure what the pros/cons are of starting up all my apps in a ramdisk.  My understanding of a ramdisk is a bit
shaky.  I've read all the docs I can find on it.  My understanding is that the ramdisk is only affecting the file system
 and not the amount of system ram I have available for running my applications.  Obviously the ram used for the ramdisk
is consummed but the rest of it should be there.
Is this correct?
Needless to say, I would think that the loopback device would stay consistent throughout the system.  But I'm finding
that not to be true.
When I start up an application in the ramdisk world, I can't connect to the apps that were started before I created the
ramdisk.
Can anyone point me to docs that describe how this works?  The devb-ram driver doc doesn't seem to touch on networking
and drivers that are loaded in the existing system.  Or maybe I just missed it.
Thanks in advance.
-stv
Re: RamDisk and wifi network driver
If I understand correctly, you are starting two instances of io-pkt-v4-hc.  This creates two independent stacks.
You probably need two instances of your app - the first started default, and the second started with "SOCK=/alt" (after
second stack is started).
You understand perfectly.
I will try that, thank you.
