Forum Topic - Installing the downloaded Network DDK failed caused by non correct Java VM: (1 Item)
Hello there...
I've downloaded the Network DDK  for Windows host ddk-devn-6.3.0-20041351145-win32.exe.
When I start this the  InstallShield Wizzard opens a Window with output "Jave(tm) Virtual Machine wird gesucht... Die
Datenträger werden nach einer Jave(tm) Virtual Machine durchsucht..." (I try to translate to english: "looking for a
Jave(tm) Virtual Machine ... the storage medias are scanned for a Jave(tm) Virtual Machine..." (?)).
From time to time the output changes to "Jave(tm) Virtual Machine 1.3.1 from Sun... is under test".
Some minutes later an other Window opens: "Es wurde keine geeignete JVM gefunden. Führen Sie das Programm mit der
Option -is:javahome <JAVA-Ausgangsverzeichnis> erneut aus." ("There is non found any suitable  JVM. Try to start again
the program with option -is:... ")
At my computer (MS Windows XP Professional V2002, Service Pack 3) there are installed JVMs 1.3.1, 1.4 and 1.7.0
(downloaded today).
Im using Momentics IDE 4.5 with QNX 6.4.0.
My Questions are:
Which JVM does the InstallShield accept?
Or may be there any other possible problems to deny the installation?
Thanks in advance,
Hans-Uwe
