Forum Topic - increase mbuf cluster size: (2 Items)
I would like to create an mbuf with cluster size to be 4K or 8K bytes. (Seems default is 2K). Is there anyway to do that
? Can I use sysctl to change kern.mbuf.mclbytes?
Thanks a lot!
Yurong
Re: increase mbuf cluster size
The sysctl is read only.  All sorts of things would break if
this changed out from under other drivers.
You can change it on the command line with:
# io-pkt -p tcpip mclbytes=4096
But your driver should also handle the defaults.
On Fri, Mar 09, 2012 at 11:24:51AM -0500, Yurong Sun wrote:
that? Can I use sysctl to change kern.mbuf.mclbytes?
> Thanks a lot!
> Yurong
> Networking Drivers
> http://community.qnx.com/sf/go/post92020
