Forum Topic - Problem in doing ifconfig on my device: (3 Items)
I am writing a wireless network driver (with io-net framework: not io-pkt framework) where in i am able to register my
driver with io-net and i am getting interface name as en0 in /dev/io-net. When i do ifconfig on my device i am getting
the following error:
No such device : en0
As i know, ifconfig acts on divice via driver devctl function which is registered to io-net using net_registrant_funcs_t
 structure. So when i do ifconfig at least my devctl should get called which is not happening in my case.
Does this mean  My driver not registered properly with io-net?
Plz let me know.
Thanks & Regards
Arun L Hegde
Global Edge Software Limited
Malleswaram
Bangalore-560 003, India
Ph:9886232054
arun.hegde@globaledgesoft.com
www.globaledgesoft.com
Re: Problem in doing ifconfig on my device
On Wed, Jan 16, 2008 at 08:42:56AM -0500, Arun Hegde wrote:
net_registrant_funcs_t structure. So when i do ifconfig at least my devctl should get called which is not happening in
my case.
> Plz let me know.
io-net learns of your driver via (io_net_self_t *)->reg().
The stack learns of your driver via the advertise packet you
have to send up: _NPKT_MSG flag set with payload of type
io_net_msg_dl_advert_t.  So either you're not sending up the
advertise packet or something is wrong therein.
Hi Sean,
Thaks for ur reply.
Actually, i was missing advertise functionality. Now i added the advertise functionality and i am able to perform
ifconfig on my device.
Thanks & Regards
Arun Hegde
