Forum Topic - QNX driver for RT2860 chipset: Page 1 of 2 (39 Items)
I have just installed (Lynksys Wireless PCI card) WMP600N in my QNX Neutrino system. QNX doesn't detect this network
card. I guess this wireless PCI card has RALINK2860 chipset, and vendor ID is 1814h, Ralink; Device ID: 601h.
Please would you advise how to make this wireless PCI card work in my system.
Palak
Re: QNX driver for RT2860 chipset
In theory it should be supported by devnp-ral.so, but current devnp-ral only support 2561, 2661.
I have ported 2860 to ral driver but I didn't test as I don't have card so probably it won't work at all. I can give you
 the binary to try next week.
I ported on weekend so I can post the binary here I guess, if I can't please let me know.
This is gentle reminder to obtain support for RT 2860 chipset. Please help us to make this device work. Actually, my
colleague (Mital Kanabar) has already asked to QNX (in the same forum) for this chipset, before purchasing this adapter,
 and we were told that it should work. Would you please check if someone there has already developed something for this?
Palak
Hi Yao,
Please provide QNX driver for RT 2860 chipset.
I would highly appreciate your support.
Palak
I attached the devnp-ral.so for 6.4.1 x86, please try.
I have not tried any pci/pci rt2860 yet.
Attachment: Text devnp-ral.so 224.68 KB
Thanks a lot Yao, how to use your attached file in my QNX? I am newbie.
QNX has some excellent product documentation and there's a wealth of
information on the networking project's wiki. As a newbie I encourage
you to take advantage of it, e.g.:
http://www.qnx.com/developers/docs/6.4.1/neutrino/utilities/about.html
http://community.qnx.com/sf/projects/networking
Cheers!
/P
> Networking Drivers
> http://community.qnx.com/sf/go/post53603
QNX doesn't detect network card
I have copied the provided devnp-ral.so in /lib/dll folder. Moreover, I have also added this device id in /etc/system/
enum/devices this folder has 'net' file. I have modified net by adding vendor ID as Ralink, and device id 0610.
I have tried several commands available in QNX docs (as follows:)
mount -T io-pkt /lib/dll/devnp-ral.so
io-pkt-v4-hc -t tcpip & mount -T io-pkt devnp-ral.so
several others, but none of this is working. Then, I have tried
slay io-pkt-v4-hc
io-pkt-v4-hc -dral
This results in error "unknown symbol bus_space_set_region_4"
I have check #sloginfo , this shows last item is "unable to load /lib/dll/devnp-ral.so: unresolved symbol"
Please... please help.
Palak
Re: QNX doesn't detect network card
> also added this device id in /etc/system/enum/devices this folder has 'net'
> slay io-pkt-v4-hc
> io-pkt-v4-hc -dral
> Palak
There are some functions not defined by libnbdrvr. I added.
Attachment: Text devnp-ral.so 168.82 KB
Hi Yao,
Thanks you so much for your consistent efforts and time for this job, I appreciate it. I copied the file (devnp-ral.so)
in x86/lib/dll folder. After rebooting system, it doesn't detect any NIC :(, then I tried to find error, in network
configuration manager it show error like this "netmanager error: could not open socket: Address family not supported by
protocol family"
Now, this system doesn't detect any network interfaces, including the existing wired Ethernet NIC. If I remove this file
 (devnp-ral.so), and reboot the system, it comes back to normal.
Please advise me.
Palak
The stack probably crashed. Check that this is the case using pidin. If
you've got dumper running, check in /var/dumps for the core file and
send it.
/P
> "netmanager error: could not open socket: Address family not supported by protocol family"
> Hi Yao,
> appreciate it. I copied the file (devnp-ral.so) in x86/lib/dll folder. After
>  network configuration manager it show error like this "netmanager error:
>  wired Ethernet NIC. If I remove this file (devnp-ral.so), and reboot the
> Please advise me.
> Thanks
> Palak
Don't modify the enumerators.
You can do this:
1)mkdir work
2)cp where/devnp-ral.so work
3)io-pkt-v4-hc -i1 -S -d `pwd`/work/devnp-ral.so verbose=5 -ptcpip prefix=/ral
4)pidin arg|grep io-pkt-v4-hc
5)sloginfo
if you can't see this 2 io-pkt-v4-hc then io-pkt-v4-hc crashed, attached the core dump under /var/dumps/io-pkt-v4-hc.
core.
if not crashed
5)SOCK=/ral ifconfig
all of the network related commands need SOCK=/ral
sorry!
Hi Yao,
I have followed your steps, this time io-pkt-v4-hc doesn't crashed because I didn't use 'mount' command (if I use it, it
 crashes). Anyways, please find the attached files with snapshot of window while executing your commands in sequence. I
have also attached snap of io-pkt-v4-hc.core
Please have a look and advise me further.
Attachment: Text to yao.zip 1.06 MB
> Hi Yao,
> didn't use 'mount' command (if I use it, it crashes). Anyways, please find the
> sequence. I have also attached snap of io-pkt-v4-hc.core
look at the snap.jpg, in sloginfo "devnp-ral.so.so" Library can't be found.
how do you run the io-pkt-v4-hc? also please specify absolute path of the driver.
Hi Yao,
Do i need any source code for running io-pkt-v4-hc?
I have copied the code provided by you in in this driver path :  lib/dll/devnp-ral.so.that becomes the absolute driver
path i guess, am i right? And then from there i have copied it to root/work directory.
i am not sure if  i have followed any wrong path?  let me advice corrective measure i have to take for removing "
sloginfo "devnp-ral.so.so" Library can't be found" erroe. Let me know if you need any further information.
Thanks for your help...
Palak
Hi Yao,
Please ignore my previous message. I have been continuously working on this. After running the commands that you have
suggested, this card is show up in "ifconfig" however, not able to show MAC address. Please see the attached jpg file.
Is this wireless card really detected or not? because I am not able to configure it.
I really appreciate your support for this.
Attachment: Image nicinfo.jpg 134.03 KB
> Hi Yao,
> After running the commands that you have suggested, this card is show up in "
> file. Is this wireless card really detected or not? because I am not able to
> configure it.
it is better:) it didn't crash
what is in output of "sloginfo" and "pidin -p io-pkt-v4-hc mem"?
Hi Yao,
Please find the enclosed "sloginfo" and "pidin.." outputs.
Again, Thanks a lot...I appreciate it.
Palak
Attachment: Text to yao-2.zip 101.76 KB
don't worry!
there is a problem in the ral_pci_attach, it even didn't enter rt2860 attach yet.
Attachment: Text devnp-ral.so 169.01 KB
Hi Yao,
I have tried this revised code, and followed the same steps. In that case, it showed MAC address of wireless pci,
however, it didn't show in "ifconfig" or "network configuration window". Please find the sloginfo for this step in"
sloginfo_may 13.jpg"
Secondly, I have added the vendor id and device id in "x86/etc/ system/enum/device/net" file, I have inserted another
row in list of Ralink devices. After restarting the QNX, it shows ral0 in "ifconfig" as well as "network configuration",
 however, it doesn't detect MAC address, Please find the sloginfo for this step in" sloginfo2_may 13.jpg".
I just want to confirm that I have not changed anything with "lib/dll/devnp-ral.so", do we need to modify it in order to
 detect the card correctly?
Please advise,
Thanks again,
Palak
Attachment: Text to Yao-3.zip 219.97 KB
> Hi Yao,
> showed MAC address of wireless pci, however, it didn't show in "ifconfig" or "
> device/net" file, I have inserted another row in list of Ralink devices. After
> configuration", however, it doesn't detect MAC address, Please find the
> ral.so", do we need to modify it in order to detect the card correctly?
> Please advise,
> Thanks again,
> Palak
this is what I guess that because you modify the vid, did to enum file so old devnp-ral.so is loaded then you see
0000000000 mac address.
the new driver I attached it will show mac address, and "rt2860 driver attached" in sloginfo.
so don't modify anything, use the instructions I put.
Hi Yao,
First of all I have tried exactly as per your instruction, without modifying anything in enum. As you have seen in first
 sloginfo_may13.jpg, It does show the MAC address, however, it doesn't show anything in "ifconfig" or "Configuration of
network devices". How to configure IP and subnet mask without looking into "Configuration of network devices" tap of QNX
Please advise me in this regard.
Thanks for your consistent help.
Palak
> How to configure IP and subnet mask without looking into "Configuration of network devices" tap of QNX.
How to configure IP address and subnet mask is not specific to the
driver. It is described in the documentation for ifconfg.
http://www.qnx.com/developers/docs/6.4.1/neutrino/utilities/i/ifconfig.html
You will also want to have a look at the networking user's guide.
http://www.qnx.com/developers/docs/6.4.1/io-pkt_en/user_guide/about.html
HTH
/P
Hi Pratik,
Thanks for your reply. I have already gone through these links. If you check my previous postings, the problem with my
network driver is that it is attached but I can't see that interface in "ifconfig". How would I know, whether driver is
working properly over the communication stack or not, as QNX doesn't show wireless network adapter (ral0) in network
interface lists. This way I can't configure this card.
Please advise.
Palak
Hi Mital Kanabar or Palak Parikh (is there two of you?),
I probably misunderstood you.
The last posting specifically asked how to configure IP address and
subnet mask: "How to configure IP and subnet mask". I tried to provide
the pointers to help with that.
It wasn't clear to me, maybe I misunderstood you, that the device didn't
show up in ifconfig. It seemed the most likely that you meant to say
that it now shows up, because I thought it unnecessary to ask how to
configure IP address when it doesn't show up, that's all...
/P
On 14/05/10 11:46 AM, Mital Kanabar wrote:
> Hi Pratik,
> Please advise.
> Palak
> Networking Drivers
> http://community.qnx.com/sf/go/post54727
