Mathieu Looten(deleted)
BeagleBoard RevC4 and D-Link E100
02/08/2010 10:54 AM
post46804
I have received a Beagleboard RevC4 with a QNX image on it.
i have connected a USB-Ethernet D-Link E100 that is suported by my image but I do not succeed to get an IP adress for
the board.
here are the commands I have run
[code]io-pkt-v4 -d asix -p tcpip,verbose
waitfor /dev/io-net/en0
dhcp.client
[/code]
Hereunder is the result of ifconfig command.
[code]
# ifconfig
en0: flags=80008a43<UP,BROADCAST,RUNNING,ALLMULTI,SIMPLEX,MULTICAST,SHIM> mtu 1500
address: 00:80:c8:3b:0f:72
media: Ethernet 10baseT
status: active
inet 0.0.0.0 netmask 0xff000000 broadcast 255.255.255.255
[/code]
as you can see the network seems to be established but I have no IP address;
here is the sloinfo report
[code]Jan 01 00:02:00 5 14 0 tcpip starting
Jan 01 00:02:00 3 14 0 Unable to attach to pci server: No such file or directory
Jan 01 00:02:00 3 14 0 Using pseudo random generator. See "random" option[/code]
Any idea on what is going wrong? previously I had a RevB with an other QNX image and the setup was ok :-(
