Forum Topic - iopkt hangs after loading 2 differnet drivers: (3 Items)
io-pkt hanged after loading 2 different drivers in QNX 6.4.1.
driver-1 (Resource Manager driver)
Here i m creating the resource manager and  network thread during io-pkt entry function.
I am handle the application messages in busy loop in my thread handler function.
Command for loading the driver
mount -T io-pkt devnp-driver1.so
driver-2 (network driver)
Its a network driver for handling the packets.
mount -T io-pkt -oifname=tsec1-tsec2 devnp-driver2.so
I have a two different application to access those drivers.
application1 - for accessing resource manager driver.
application2 - for accessing the network driver
1.Loaded the driver1 successfully.
2.Run my application1  - its working successfully.
3.Loaded the driver2 successfuly.
4.Run my application2 - its hanged.
when i see the sloginfo ,i got the debug statements  "quiesce callout function".
This function is present in driver1(resource manager driver).
I dont know why the driver 1 quiesce callout function gets invoked while accessing the driver2.
Janani
RE: iopkt hangs after loading 2 differnet drivers
> io-pkt hanged  ...
This kind of problem is generally pretty easy to diagnose.
Run pidin, and get the pid of io-pkt.  Then run
  # dumper -p N
where N is the pid of io-pkt.  This will create a core
file, just as if io-pkt had faulted.
Then, using gdb, load the corefile and do a backtrace
of each of the threads.
aboyd
Re: iopkt hangs after loading 2 differnet drivers
On Wed, Dec 16, 2009 at 11:58:53PM -0500, Janani K wrote:
Please check out this thread:
http://community.qnx.com/sf/discussion/do/listPosts/projects.networking/discussion.drivers.topc11227
You have to do more than spit out a debug message in your
quiesce_callout.
