Forum Topic - io-pkt hangs because of nw_pthread_create function.: (10 Items)
I have 2 different network drivers  (devnp-sam1.so and devnp-sam2.so).
devnp-sam1.so  - handling messages
1.i have created the resource manger ,nw_pthread_create() in iopkt entry function.
2.In thread handler function is in busy loop to handle all the messages
code snippet - devnp-sam1.so
iopkt_entry
/* i create resource manager also. */
nw_thread_create(&thid,0,my_handler,NULL,0,my_init,NULL);
my_init()
           struct nw_work_thread *wtp;
           wtp = WTP;
          wtp->quiesce_callout = my_quiesce;
          return EOK;
my_quiesce()
 printf(" inside quiesce\n");
my devnp-sam1.so loaded successfully.
devnp-sam1.so
1.this is  my network driver for handling the packets.
my second driver also loaded successfully.
if my application try to access my devnp-sam2.so(network driver) its hanged.
After that if i do ifconfig its also hanged.
if i load only one driver either devnp-sam1.so  or devnp-sam2.so.
the drivers are working properly,my application is not hanging.
But if i load both the driver and run my application.
if i run my application my_quiesce function got invoked and displays
"inside quiesce" and then iopkt got hanged.
What should i do to run my network driver simulatenously.
Please help me if i missing any thing.
Thanks and Regards
K.Senthil
Re: io-pkt hangs because of nw_pthread_create function.
On Tue, Dec 15, 2009 at 06:38:11AM -0500, Senthil K wrote:
> my_quiesce()
my_quiesce() is obviously incomplete.  It has to
poke your thread into calling quiesce_block().
The main thread in waiting for this to happen.
Hi Sean,
Thanks for ur reply,
I have refered some of the code in QNX 6.4.1 Networking source code in which theyare using quiesce_callout function.
Inside the quiesce_callout function,they are using
ex 1:
quiesce_block(0)
ex -2:
quiesce_block(1)
what is the difference  of passing 0 and 1 in quiesce_block function?
Thanks and Regards
K.Senthil
"Use the source Luke" :-)
Take a look at the code lib/io-pkt/sys/quiesce.c
/P
I have used quiese_block(1) and quiesce_block(0) in my quiesce_callout function.
but still its hanging.
Thanks and Regards
K.Senthil
On Wed, Dec 16, 2009 at 05:34:44AM -0500, Senthil K wrote:
You don't call it from the quiesce_callout().  quiesce_callout() is
supposed to poke your newly created thread into calling it.  For
example, if one were to create a thread that blocks in MsgReceive(),
queiesce_callout() might send it a pulse with a pre-determined code
to unblock it and call quiesce_block().  This 'poking' mechanism
is up to you as you control the communication mechanism between
quiesce_callout() and your newly created thread.
Hi Sean,
Thanks for reply.
yesterday i told that if i do ifconfig its hanging.But today my observation is its hanging for 4-5 minutes and then
command prompt is coming.
once again if i give ifconfig its hanging.
i think this because of my network thread not scheduling properly.
Please help me.
Thanks and Regards
K.Senthil
Hi Sean,
Thanks a lot for your support and reply.
I  have followed nw_phtread_creation from nraw_res.c,Now I am able to load my 2  different drivers in io-pkt thread.
Thanks and Regards
K.Senthil
hi all
Please attach the file "nraw_res.c" on this post, or show an example of code using "nw_pthread_create"
I can not understand how to use "quiesce_block", because after the call, as well as "quiesce_callout" - it hangs "io-pkt
", all threads are in a state CONDVAR - and wait some event.
In the help function on "nw_pthread_create" has a reference to "net/ppp_tty.c", where can I get it?!
thank you.
Unfortunately source code access is closed. You will have to contact
sales/support.
