Trackers
Trackers
Forum Topic - Problem to start QNX Momentics IDE 4.0.1: (5 Items)
I have installed $subj at MS WIN XP version 2002 SP 3 (Czech version). When Im trying to start it QDE error message
appears "An error has occured. See the log ..."
I have tryied to reinstall it but with the same result.
here is the log
note that "Systém nemůže nalézt uvedenou cestu" is "Path not found" (I did not want to touch the log file with
translation).
Thanks for any kind of help.
malo
Attachment: Text .log 6.54 KB
Re: Problem to start QNX Momentics IDE 4.0.1
Looks like permission problems. Was tool installed as admin and you are trying to start it as user?
pavol malosek wrote:
> Hello,
> here is the log
> note that "Systém nemu*že nalézt uvedenou cestu" is "Path not found" (I did not want to touch the log file with
translation).
> malo
> http://community.qnx.com/sf/go/post15721
I'm trying to run it under the same account as it was used for installation - Account with admin rights.
malo
It is trying to create some temporary files during launch (looks like) and failed to create them.
How you trying to start it?
> malo
> http://community.qnx.com/sf/go/post15731
Today I gave a try to new 4.5 IDE from 6.4 but with the same result, well almost it was not showing me that error
message only crashing silently...
Anyway I have found out that the problem was in wrong permissions for c:\Documents and Settings\USERNAME\momentics
directory. After installation only SYSTEM group has write permissions. When I gave full control for USERNAME user to the
 momentics directory IDE starts nicely.
Thanks for hint with permissions.
malo
