Trackers
Trackers
Forum Topic - "Find and Install..." fails under Neutrino IDE 4.0.1: (5 Items)
My experience is the same as mentioned for a qconn update recently; after selecting Help->Software Updates->Find and
Install..., the system thinks for a bit and then nothing--no dialog at all. Is this a known problem?
Re: "Find and Install..." fails under Neutrino IDE 4.0.1
This is due to missing SSL implementation in the Java VM. Yes it's a known issue in IDE 4.0.1.
We are working on adding SSL support to the VM in the IDE Tau release.
Is there perchance a work-around for downloading plugins outside eclipse and installing them?
Yes you can download most of eclipse plugins in zipped form and extract
in IDE installation directory
> http://community.qnx.com/sf/go/post9787
Thanks, I'll give that a try.
