Trackers
Trackers
Forum Topic - ELF file issues: (5 Items)
ELF file issues
Just downloaded QNX and trying to understand it. I have a bunch of ELF files. I'm trying to understand if there is any
way I can open them and see the source code that is stored in them if any. I'm trying to run these processes in the BIN
folder but I have no idea where to start. Is there a way to see the source code? Maybe dis assembly them or de compile
them? Do I have to do something with all SO files in the LIB folder?
When I open them up with IDE I got some characters I can read and the format looks good but most of it is gibberish
characters.
See attached images of the file I am looking at.
Thank you in advance
Attachment: Image DIRECTORY-2.png 79.74 KB Image DIRECTORY-1.png 194.16 KB
Re: ELF file issues
ELF files are binary files. There is no source code that stored in them. If you can convert them to assembly using
readelf utility if you good with assembler code.
Re: ELF file issues
There is also ntox86-objdump, assuming they are x86 executable.
Good luck.
Re: ELF file issues
In the .TAR file space though its executing some code is it not? I don't want to waste my time trying to sniff through
assembly language code if its just giving me header information about the ELF file itself. I was told these processes
located in the .TAR perform an operation. If I use one of these utilities I just want to make sure im looking at the
application code that is performing the work and not some ELF file header information.
Re: ELF file issues
> to waste my time trying to sniff through assembly language code if its just
> processes located in the .TAR perform an operation. If I use one of these
> utilities I just want to make sure im looking at the application code that is
I am sorry I cannot help you what you saying does not make any sense. Tar is file archive container it does not execute
any code. I suggest you talk to your supervisor or colleagues about your issues first.
