Trackers
Trackers
Forum Topic - Prosess [pid] in timeline (tracelogger in ring mode): (13 Items)
IDE401
when viewing a kev file generated from tracelogger in ring mode we see the string "Prosess" followed by [somepid] in
timeline instead of OrigProcessName [pid].  Is it planed that we can change/edit the string
"Process" manually to real process name the case set, that there is a pretty  good reason for the things actually
displayed as  "Prosess [pid]" in the timeline view ?
Jeevan
Re: Prosess [pid] in timeline (tracelogger in ring mode)
The reason for this is quite simple.
TraceEvents like "CreateProcessName" which the IDE takes the information about process names from, are triggered only
once on tracelogger start/attach to procnto-instr by procnto itself.
If your trace now runs long enough, these events will be overwritten because you're running in "ring mode".
I don't now if QNX has a plan for making process names editable int the IDE, but what you can do, is to append
appropriate "CreateProcessName" events to the tracefile, this is a bit tricky - but it works (we do this for threadnames
 on 6.3.0 which has no threadname support).
-hp
Hey HP - why not extend your util to add the process names too - then you could post it to the bazaar project. :-)
Colin
> about process names from, are triggered only once on tracelogger
> IDE, but what you can do, is to append appropriate "CreateProcessName"
> for threadnames on 6.3.0 which has no threadname support).
> -hp
> http://community.qnx.com/sf/go/post4919
cburgess@qnx.com
that's already on the way, it's one of the next tasks of Thomas S.
hope you had a good flight.
I tryed to find an example on how to add a ProcessName Event at the end of a ringbuffered kernel event trace, but I
couldn't find one.
I managed to insert a PROCCREATE_NAME Event, but there is only one row in the traceprinter output (containing the ppid
and pid, but not the name).
Could someone please post a small example, how add the process names?
Thank You!
I have some code around that adds thread names.  I can send that your way and
you should be able to adapt it to your needs.
Let me fish around for a few minutes...
> of a ringbuffered kernel event trace, but I couldn't find one.
> in the traceprinter output (containing the ppid and pid, but not the name).
> Thank You!
> http://community.qnx.com/sf/go/post5736
cburgess@qnx.com
Did you already find an example?
Thank You!
stay tuned, coming soon
I have to strip the example down to the essentials
/hp
okey dokey, here we go ...
see the attachment, it is an example of how to do this.
I didn't test this one 'til now - it'san adaption of a different function which is inserting thread names for traces of
an 6.3.0 system.
But it should work - maybe except of compilation errors.
you will need to provide the list of names,  pids and ppids.
I hope the source is self explaining, if not and you have more question - just ask
/hp
Attachment: Text append_process_names.cpp 2.37 KB
Thanks a lot!
the source is pretty much self explaning. I did not know one has to mess around with this beg, cont & end header thing.
This was one of the missing pieces...
To get it working for me (on a 6.3.2er version), I had to add 1 to the position of the last timestamp and to the "add
the process names here" position in the file. Otherwise the timestamp was wrong and thus it was not possible to open the
 .kev file in the ide.
Thanks again!
Greets,
Matthias Ecker
The beginning of each timestamp must aligned to the size of a 'simple' event.
The safest way to do this involves parsing the header to find the beginning
of events, and then doing a modulo on the event size to make sure the rest
of the events are 'whole'.
Colin
> Thanks a lot!
> around with this beg, cont & end header thing. This was one of the
> missing pieces...
> position of the last timestamp and to the "add the process names here"
> not possible to open the .kev file in the ide.
> Thanks again!
> Greets,
> Matthias Ecker
> http://community.qnx.com/sf/go/post6482
cburgess@qnx.com
Hi all,
I know it has been a while since the last entry to the post but I tried the example code on 6.4.1 and it didn't work.
The IDE reported my file as being corrupted.
Can anybody send me a version of the code working with 6.4.1 ?
Tobias
AW: Prosess [pid] in timeline (tracelogger in ring mode)
I think you have to check your implementation.
It is still working for me, without any change to my original code.
trace was done on a 6.4.1 system and I am using IDE 4.6.1 build 20100115
/hp
>Von: Tobias Schwarz [mailto:community-noreply@qnx.com]
>Gesendet: Donnerstag, 18. März 2010 23:22
>An: general-ide
>Betreff: Re: Prosess [pid] in timeline (tracelogger in ring mode)
>Hi all,
>but I tried the example code on 6.4.1 and it didn't work. The
>Tobias
>General
>http://community.qnx.com/sf/go/post49961
