Trackers
Trackers
Forum Topic - Changing QNX_HOST and QNX_TARGET does not work: (8 Items)
I have Momentics IDE installed on D:\QNX650.
I have a set of includes and libraries that are different from default ones shipped with Momentics.
I put them into an other directory called D:\QNXABC and modified QNX_HOST to D:\QNXABC\host\win32\x86 and QNX_TARGET to
D:\QNXABC\target\qnx6 from qwincfg.exe.
Although the global environment variables QNX_HOST and QNX_TARGET are changed, Momentics IDE still use default QNX_HOST
and QNX_TARGET which point to directories under D:\QNX650.
Would you please tell the correct way to modify these settings?
Re: Changing QNX_HOST and QNX_TARGET does not work
You can edit configuration file (xml) which has these defined
Where does your QNX_CONFIGURATION variable points to?
On 03/28/2011 04:29 PM, Gang Li wrote:
to D:\QNXABC\target\qnx6 from qwincfg.exe.
QNX_HOST and QNX_TARGET which point to directories under D:\QNX650.
> Thanks,
> http://community.qnx.com/sf/go/post84344
RE: Changing QNX_HOST and QNX_TARGET does not work
In IDE global preference page "Windows -> Preferences -> QNX -> Select
Install:", choose the "Use Environment Variables" and restart your IDE.
Sent: March-28-11 4:30 PM
To: general-ide
Subject: Changing QNX_HOST and QNX_TARGET does not work
changed, Momentics IDE still use default QNX_HOST and QNX_TARGET which
Re: RE: Changing QNX_HOST and QNX_TARGET does not work
I did so but when I start Momemtics IDE, it pops up a QNX Configuration Error windows and says QNX_CONFIGURATION is not
defined correctly or the location it points to is not accessible.
However, if I still select 'Use Environment Variables' in QNX global settings and do not modify QNX_HOST and QNX_TARGET,
 the IDE can start without any problem.
RE: RE: Changing QNX_HOST and QNX_TARGET does not work
See Elena's realy reply, where is your QNX_CONFIGURATION env var points
to. I understand you created "D:\QNXABC" but you need to define a QNX
installation to make it valid. You can copy your QNX650 configration xml
file to a new one and modify it.
BTW this is wired why do you have to muck around with the new QNX_HOST
and QNX_TARGET?
Sent: March-28-11 5:04 PM
To: general-ide
Subject: Re: RE: Changing QNX_HOST and QNX_TARGET does not work
Error windows and says QNX_CONFIGURATION is not defined correctly or the
settings and do not modify QNX_HOST and QNX_TARGET, the IDE can start
Re: RE: RE: Changing QNX_HOST and QNX_TARGET does not work
I am working on a new platform and default headers and libs are incompatible with this new platform.
This is why I need to modify QNX_HOST and QNX_TARGET.
Or, it will be better if I can override these settings in my project. Can I do this?
RE: RE: RE: Changing QNX_HOST and QNX_TARGET does not work
Not at the project level. This settings are global. You can use
different workspace for different platform.
Sent: March-28-11 5:14 PM
To: general-ide
Subject: Re: RE: RE: Changing QNX_HOST and QNX_TARGET does not work
Can I do this?
Re: RE: RE: RE: Changing QNX_HOST and QNX_TARGET does not work
I made this.
I duplicated configuration.xml in the same directory and modified host and target settings. Now I can switch back and
forth with different targets.
Thank you all.
