Peter Weber
03/10/2011 7:53 AM
post83890
Hi *,
we tried to use the librcheck.so from the patch for IDE but we run into the same problem as before. What I'm doing wrong
# use -i /mnt/app/armle/usr/lib/librcheck.so.1
NAME=librcheck.so
DESCRIPTION=memory analysis malloc library DATE=2010/08/09-10:52:02-EDT STATE=Experimental HOST=elaskavaia-linux USER=
elaskavaia
/mnt/app/armle/usr/lib/librcheck.so is a symbolic link to /mnt/app/armle/usr/lib/librcheck.so.1 :
# ls -als /mnt/app/armle/usr/lib/librcheck.*
1 lrwxrwxrwx 1 root root 14 Jan 01 01:27 /mnt/app/armle/usr/lib/librcheck.so -> librcheck.so.1
419 -rwxr-xr-x 1 root root 214409 Mar 10 2011 /mnt/app/armle/usr/lib/librcheck.so.1
376 -rwxrwxrwx 1 root root 192347 Mar 03 2011 /mnt/app/armle/usr/lib/librcheck.so.1.old
376 -rwxrwxrwx 1 root root 192347 Mar 03 2011 /mnt/app/armle/usr/lib/librcheck.so.old
An attempt with a binary named slogprint we wrote and LD_DEBUG-Outputs:
# LD_PRELOAD=librcheck.so LD_LIBRARY_PATH=/armle/lib/:/armle/usr/lib:/eso/lib MALLOC_FILE=/tmp/test.rmt LD_DEBUG=all ./
slogprint "bla bla"
libs: load_object: attempt load of librcheck.so
debug: find_file:1151: name=librcheck.so libpath=/armle/lib/:/armle/usr/lib:/eso/lib rpath=NULL
debug: searchpath:1095: name=librcheck.so path= amode=4 bufsize=1025
debug: searchpath:1095: name=librcheck.so path=/armle/lib/:/armle/usr/lib:/eso/lib amode=4 bufsize=1025
debug: searchpath:1119: trying /armle/lib/librcheck.so
debug: searchpath:1130:/armle/lib/librcheck.so: failed (No such file or directory)
debug: searchpath:1119: trying /armle/usr/lib/librcheck.so
debug: searchpath:1124:/armle/usr/lib/librcheck.so: success
libs: /armle/usr/lib/librcheck.so: found; real path:/mnt/app/armle/usr/lib/librcheck.so.1
libs: load_elf32: loaded lib at addr 78000000(text) 78026150(data)
libs: object librcheck.so loaded; real soname: librcheck.so.1 loaded from: /mnt/app/armle/usr/lib/librcheck.so.1
unknown symbol: main
ldd:FATAL: Could not resolve all symbols
cheers,
Peter
