Arun Parameswaran
Debugger terminates with 'Illegal Instruction' (SIGILL) when Stepping through code
Arun Parameswaran
09/27/2010 2:52 PM
post68687
I am using QNX Momentics IDE Version: 4.7.0, Build id: 201006232051 and running QNX 6.5.0 in the target (ARM-le).
I created a test project (QNX C Project) to see if I can step through the code with just a 'main()' and couple of
'printf()' (I have also tried by adding function calls and eluminating printf() but with the same issue).
I had set multiple break points and I started the debugger (with verbose) and the program stopped at main() as expected.
Then I did 'resume', it went to the first breakpoint.
I then did 'step over' twice and the debugger terminated with 'Illegal Instruction'.
I am sure that it has not exited the main() function.
Seems like it has something to do with the 'libc.so.3'. I double checked to see if I loaded the correct library file
(libc.so.3) in the target.
The following is present in /usr/lib
ldqnx.so.2 -> ../../proc/boot/libc.so.3
I have 'qconn' and network running on the board (no'inetd'). I also have serial connected (Ran it with and without the
Terminal connected). I am able to view the 'QNX System Perspective' so I think that the 'qconn' is functional.
There is only one source file and the contents are as below. I had the first breakpoint set at the second 'printf()'
statement and the next at the 5th printf().
#include <stdlib.h>
#include <stdio.h>
printf("Welcome to the QNX Momentics IDE\n");
return EXIT_SUCCESS;
Please help me understand what I am missing to be able to step through the code.
Attached are logs from the console.
Arun
