Forum Topic - Overlays versus Layers: (5 Items)
Could I assume, that I can always target the same hardware scaler, while using overlays and/or layers API ? Is it
possible that when graphics driver reports, that it has one YUV/RGB overlay supported and simultaneously reports that it
 have two layers, one of them is main display layer and the second one is the same overlay ?
Can I rely on the layers API only while using Photon or standalone GF (since it doesn't have overlays API), if graphics
driver has overlay support, then this overlay(s) could be always accessed as one of the layers ? Is this true ?
RE: Overlays versus Layers
If I understand things correctly, in QNX SDP 6.4.0 or newer, an overlay == layer with a particular format, and/or
capabilities ... internally io-graphics deals straightly with layers, all the 'scaler' operations are interpreted.
From: Mike Gorchak [mailto:community-noreply@qnx.com]
Sent: Tue 07/04/2009 9:19 AM
To: photon-graphics
Subject: Overlays versus Layers
Photon microGUI
http://community.qnx.com/sf/go/post26195
Attachment: Text winmail.dat 3.55 KB
Re: RE: Overlays versus Layers
> layer with a particular format, and/or capabilities ... internally io-graphics
So video scaler API in the graphics driver is deprecated too (and is not used anymore) ? This sounds good.
An overlay is just a "layer".  Newer drivers only support the layering interface, older driver may still have the old ‘
scaler’ interface.
You should be able to everything with the layer interface, is something missing?
-Derek
> interface, older driver may still have the old ‘scaler’ interface.
> missing?
Ok, thanks.
