Forum Topic - pterm behavior: (4 Items)
pterm behavior
Inside a pterm running a shell, i start a program which SIGSEGV and I can see the message Memory Fault.  That's fine
But if I do pterm -z program, when the program crashed the pterm title becomes "idle 0" and stay open ( because of the -
z ), but the message Memory Fault is no where to be found?  How do I make it show up?
Re: pterm behavior
>  "idle 0" and stay open ( because of the -z ), but the message Memory Fault is
If I add -v to proc it will show information about the crash, but the message Memory Fault is not there.
Re: pterm behavior
"pterm -z sh -c program" should do it...  It's the shell that normally prints out the message.
Re: pterm behavior
> becomes
> is
> out the message.
Yep that work, thanks, however that would make our startup procedure too complexe (starting useless shells)   By using -
v on proc, that solves my problem.
Cheers!
