Forum Topic - PS2 Mouse not working on initial boot into Photon: (12 Items)
Platform:
COMMELL LS-570 x86 PC
QNX 6.4.1
USB Disabled
Configured to not boot directly into Photon
1. Boot into text mode
2. Test mouse is operational in text mode using "hidview -a" and then moving mouse
3. Launch Photon "ph"
4. Mouse is not operational but the PS2 keyboard still works
5. Checked args for devi-hid: "mouse kbd"
6. Logout to text mode
7. Restart Photon - Mouse and keyabord are both operational
8. Checked args for devi-hid: "mouse kbd"
To get around this issue I have added the following to the phapps file so I don't have to exit:
slay -f devi-hid
devi-hid mouse kbd
I would rather not have to have a workaround.
Any help / insights would be appreciated.
- Richard
Re: PS2 Mouse not working on initial boot into Photon
Hi Richard,
Thats odd that its not picking up the mouse.  The devi-hid driver doesn't init the hardware in anyway (devh-ps2ser.so
does that work).  The only thing that I can think of is that its not getting the report for the mouse packets.  If you
modify your ph script so that it starts up with
devi-hid -vvvvvvvv kbd mouse > /tmp/devi_log.out 2> /tmp/devi_log.err
Then move your mouse around the screen and then exit photon.  Then post the output.
There should be an error if devi-hid was unable to attach to the mouse reports.
Best regards,
Erick
> Platform:
> QNX 6.4.1
> USB Disabled
> mouse
> don't have to exit:
> slay -f devi-hid
> devi-hid mouse kbd
> Thanks,
> - Richard
Two set of files attached. The .nomouse. files are from the initial launch into Photon. The .mouse. files are from the
subsequent re-launch of Photon after exiting to text mode.
Attachment: Text devi-hid.tar.F 10.14 KB
> into Photon. The .mouse. files are from the subsequent re-launch of Photon
Oooo tar.F been a while since I saw one of those ;)
Apparently its been a while since I used them too, melt devi-hid.tar.F results in the expected .tar, however tar is
telling me the archive is corrupt and a quick spatch of the file is telling me something is not right.  Is the archive
corrupted by chance?
Best regards,
Erick
Try:
freeze -dc devi-hid.tar.F | pax -r
> Try:
I tried that and pax complains that the archive doesn't look valid.  Looks like it got corrupted.
Best regards,
Erick
Ok, lets try this one.
Attachment: Text devi-hid.tgz 9.87 KB
Thats interesting, you successfully attach to the mouse reports, however you never receive any reports.  I'm inclined to
 think that the issue is with devh-ps2ser.so, however if you were able to get data from 'hidview -a' then that would
seem to reason that it's not the one at fault.
Could you try modifying your ph script so that when it calls 'inputtrap' get rid of that and call
devi-hid kbd
sleep 2
devi-hid mouse
And let me know if that yields a different result?
Erick
> devi-hid kbd
> sleep 2
> devi-hid mouse
From hard or soft restart I get inconsistent behaviour - sometimes it works, but more often it doesn't. A couple of
times even the keyboard was not functional.
Could it be that devi-hid has a dependency on something that is not fully available until later in the Photon startup
and then once available it survives exit to text mode and back into Photon?
> > devi-hid kbd
> > sleep 2
> > devi-hid mouse
> but more often it doesn't. A couple of times even the keyboard was not
> functional.
> available until later in the Photon startup and then once available it
Hi Richard,
Not really, the input driver (depending on how it was started) needs to see that Photon is running, once it sees that it
 will be able to issue the Photon events, it will complain if it doesn't see that its running.  If it was a case where
it was depending on something, the last suggestion would have addressed that I would imagine, also the kbd module would
be failing as well as it uses the same interface that the mouse does to communicate with Photon.  Also you are not even
getting the reports from the HID server (io-hid) which happens _way_ before the Photon stuff.
You could try changing the ph script so that it doesn't call _any_ input drivers, and then telnet to the system once
Photon is up you can start the input driver manually and see.
Another thing to try is to telnet in, slay and restart io-hid and then start Photon and see if that makes any difference
Best regards,
Erick
Ok here is what I have found.
1. Not starting any input drivers from /usr/bin/ph and then starting them after Photon is up did not help the situation
- it resulted in the same behaviour.
2.  Not starting any input drivers from /usr/bin/ph and slaying and restarting io-hid before starting the input drivers
once Photon is up did not help either.
3. Using devi-hirun with the -R option to kbd (don't reset the keyboard) seems to work. I say 'seems' because of the
inconsistent behaviiour I have witnessed in the past - i.e. it may have worked for my 10 trial runs but it may not work
on the next run. I will post back in a week to confirm success or in less time otherwise. I now have an inputtrap file
with the following:
"kbd -R kbddev ps2 mousedev"
It appears that devi-hid does not have such an option.
4. Using devi-hirun without the -R option to kbd gives the troublesome inconsistent behaviour.
Questions:
1. Why is there two drivers for the same stuff: devi-hirun and devi-hid? You would think QNX would want to minimize the
code it has to maintain and not have to make same fixes / enhancements in multiple code files.
2. If it is the reset why would it not produce conistent results - i.e., always result in the keyboard or mouse not
working?
Hi Richard,
devi-hirun is an older legacy driver, and to be honest I was going to request that it be removed from the latest release
, however it would seem that there are still problems with devi-hid.
Now that being said the code in question is actually part of a lib that both devh-ps2ser and devi-hirun share so there
is not much overhead in maintaining both.
Since they both share the same code they share the same options.
http://www.qnx.com/developers/docs/6.4.1/neutrino/utilities/d/devh-ps2ser.so.html
There are options in the modules that will allow you to not reset the device, depending on how you are starting the devh
-ps2ser.so driver will determine what options you can add in.  After a boot, run pidin arg and then slay and restart the
 driver with the new options to suppress the reset and see if that helps.
Best regards,
Erick
> after Photon is up did not help the situation - it resulted in the same
> behaviour.
>  io-hid before starting the input drivers once Photon is up did not help
> either.
>  to work. I say 'seems' because of the inconsistent behaviiour I have
> may not work on the next run. I will post back in a week to confirm success or
>  in less time otherwise. I now have an inputtrap file with the following:
> Questions:
> would think QNX would want to minimize the code it has to maintain and not
> always result in the keyboard or mouse not working?
